Old 08-30-2007, 07:32 AM   #1
scejmer
scejmer's Avatar
transfercase
i just found the mount between the trans (350) and the transfercase is broken, thought i found one but the replacement one is only less than half the thickness of the one in the truck, checking around found it to be a possible gear to gear case? anyway does anyone know about these or possible fix, repair,or where to find one. thanks again scott
scejmer is offline   Reply With Quote
Old 09-03-2007, 05:37 AM   #2
JimKshortstep4x4
Re: transfercase
If you have an NP 205 transfer case, (as in the posted picture) you will need an adapter which has the mount on it.
Here is a possible source as they have new and used parts for transfer cases and other driveline components.
www.drivetrain.com
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
