Old 08-30-2007, 02:09 PM   #1
djohnson
Frame interchange?
I have finally given up on finding a good 77-80 replacement frame for my 78 K5. The only good frames that I have been able to find have been later model frames. The one that I purchased is an 84.
The body mounts appear to be in the same places, but they require different body mount kits. Can anyone tell me what I need to do to use this frame under my 78 body tub?
djohnson is offline   Reply With Quote
Old 08-30-2007, 04:09 PM   #2
Zoomad75
K5Camper
Zoomad75's Avatar
Re: Frame interchange?
The differences are in the mounts themselves. Take a look at LMC's catalog page for the body mount kits. They have a good drawing that shows the differences betwen the years. Basically, the body mounts in position 1,2,3 (positions starting at the core support going to the rear) differ between the years, but they are in the same place. You should be able to mix and match based on the frame and body you are going to put together.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 08-30-2007, 04:10 PM   #3
Zoomad75
K5Camper
Zoomad75's Avatar
Forgot the link....
http://www.lmctruck.com/icatalog/bzc/0022.asp
Rob Z.
Old 09-05-2007, 11:23 PM   #4
Baseball0684
Does the 78 have the middle body mounts (ones behind the front seat) mounted on the crossmember or the ears on the frame rails so they are mounted outside the frame?
73 2wd Blazer lowered, cammed ls1
89 Honda CRX 400whp daily driver. low 11's 1/4 mile and 30mpg
Baseball0684 is offline   Reply With Quote
