Old 08-30-2007, 02:40 PM   #1
CUSTOM DELUXE
CUSTOM DELUXE's Avatar
Need Help And Info For Column Swap 60-66
I was just wonder if you guys have changed a column out of a 60-66 for one out of a newer model van or truck. The one I have is a tilt without the key. My question is how do you adapt the wiring from the old column to the newer tilt, and also is there a bracket or do I make one to mount it.I'm a BIG GUY and I need the belly room, also, I'd like to make it look like it came from the factory with the tilt.
CUSTOM DELUXE is offline   Reply With Quote
Old 08-30-2007, 03:58 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Need Help And Info For Column Swap 60-66
I cut the plug from the harness from the van I took the column from and made a junction plug with that and the plug from the 65 column.. The colors are almost the same and it fairly easy to figure out.. Also.. I welded two nuts on the bottom of the column and bolted it go the stock mount. Here are some pictures... The lower shaft was from a 92 Impala but one from a 70's truck will work too... The bottom picture kinda shows the juntion harness I made up.. The brake handle is in the way a bit though..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 08-31-2007, 08:51 AM   #3
CUSTOM DELUXE
Hey Thanks Chevy Fleetside! pics are great. Gives me a visual. I appreciate it..
Old 09-01-2007, 02:09 PM   #4
Woogeroo
Power Steering and a Tilt Wheel for the '65
That may help as well...
-W
Woogeroo is offline   Reply With Quote
Old 09-02-2007, 07:20 PM   #5
60ratrod
yes, i do
60ratrod's Avatar
the column in my 60 is from a 71 chevy truck, non tilt floor shift. the column swap was relatively easy and i believe we used the factory mounts
60ratrod is offline   Reply With Quote
