![]() Join Date: Mar 2003
I had my 72' 3/4 GMC truck restored and the the guy that restored it didn't mark where the shaft came off the steering box. I still have to take the truck down to have it aligned. After it is aligned what is the best way to straighten the steering wheel if its not straight?, and if I have to take the steering wheel off to straighten it, how do I do this and how does the GMC emblem in the middle of the steering wheel come off.?Thank you all.
Sophomore Member
![]() Join Date: Jul 2006
Re: how to straighten steering wheel?
the horn button just pops off. you do have to remove steering wheel. any parts store should have a puller, you must use one. they are easy to use and the steering wheel is just put back on straight and tightened back up. make sure to get horn button back on correctly, you will have to remove that assembly as well, but all in all it is super easy. get done and snap horn button back on and you are done. i'm no mechanic, but i've done it a bunch with no problems.
1972 Chevrolet Highlander SWB 1972 Custom Deluxe 3/4 2WD 60k miles these trucks don't need vacuum gauges cause they don't suck! two wrongs don't make a right, but three rights do make a left all i want is a little more than i'll ever get it's better to be judged by 12 than to be carried by 6 |
you can rent a puller at autozone for free (after you bring it back)
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
its all about the +6 inches
there is a dot on the shaft, and on the wheel, line them up.
When they do your front end, the wheel should then be straight. |
Designated A-hole!
But just to make sure, straighten your wheels before you start.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
i agree with longhorn... tell em at the aligment shop and they should do it for ya.. thats what i did when i took mine to he front end shop. no extra charge....
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 |
![]() Join Date: Feb 2002
Disconnect the battery, or at least the horn relay connector, before you pull off the horn cap. Otherwise the blaring horn noise will bug you until you rip the battery cables loose. BTDT.
The guy restored your truck,but doesn`t know how to line-up the steering wheel????Maybe I`m missing something here.
the horn should still work as intended with the button removed... press the ring, it honks, let go, it stops.
