Old 08-31-2007, 10:10 AM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
2 questions
In the photo with the zip tie that I am trying to use to keep choke off is it
affecting the secondaries from opening. I think that rod golden rod opens the secondaries. The other photo is for someone to show me how/where I adjust the idle. It needs to come up just a tad. It will run all day in park but at a stop light with the truck in drive and my foot on the brake it will sometimes try to die as well. Thanks
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 08-31-2007, 11:52 AM   #2
ckhd
ckhd's Avatar
Re: 2 questions
Sounds like you have carb issues. Maybe you should think of getting it fixed instead of trying to band-aid it.
First, yes, the zip tie is interfering with your secondaries. That vacuum thing doesn't open the secondaries, it keeps them closed. Tying it in that position is tying your secondaries closed.
Second, in the second pic, close to where it says "Quadrajet" should be a screw that will adjust idle. However, there are two screws in the front that adjust the idle circuit (In the second pic, you can see it on the front of the carb at the bottom - gold colored screw). Those need to be adjusted first.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 08-31-2007, 11:56 AM   #3
ckhd
ckhd's Avatar
Re: 2 questions
By the way, I notice you are missing your choke rod. If you are having choke issues, get a choke rod, and a new choke coil and fix it right. The old design may be simple, but just ask my '72 burb, and it will tell you that simple works just fine.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 08-31-2007, 12:53 PM   #4
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: 2 questions
The carb was just rebuilt by SMI (sean Murphy Induction in CA. The carb works fine. I do not have a proper choke set up. I have the choke rod but the thermostat spring it is connected to is too tired to work properly. It is not an issue in TX not to have a choke this time of year. I can move the zip tie to fix choke. Which direct do I need to turn them and do I need to adjust both?
Old 08-31-2007, 01:06 PM   #5
ckhd
ckhd's Avatar
Re: 2 questions
The one screw that is near the "quadrajet" should be backed clear off so it isn't 'pushing the pedal' at all. Then, back off both of the screws on the bottom, this will make the idle circuit run rich. Then, one at a time, slowly screw them in until the rpms at idle drops slightly, then back them back out 1/2 turn. After that, if your rpms are still too low, use the screw near the "quadrajet" to raise the idle rpms. I think the proper idle speed for an automagic is something like 800rpm. You might have a tune-up sticker somewhere that will tell you for sure.
Texas or not, I'd still replace the spring. Not only will it close the choke when it's cold, but it will open the choke when it's not and eliminate the need to zip tie anything.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 08-31-2007, 10:29 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Re: 2 questions
BB72, I don't use my choke in the summer for my 69 chev with 350 and it starts fine also. My 6 cylinder GMC, however, balks a little if I don't choke it slightly when starting cold from sitting overnight. Once it's warmed up and during the day, I don't need it.
Mind you, this is during the summer only. Come winter time, you might want the choke on yours. Here's a sight that sells them. Check it out. My 69 is on the blink right now so I'm going to wait to buy one for it.
http://www.brotherstrucks.com/prodin...number=CS41B00
68gmsee is offline   Reply With Quote
