![]() Join Date: Jul 2007
I just flushed my radiator with the garden sprayer (while it was out) and now it leaks. I have a 3 speed 67 C20 with a 283 and no air. Someone installed a radiator from an automatic truck. The thing was working fine till I flushed it out with the garden hose. Now I have a leak coming from the bottom trans cooler fitting. It just pours our like it's a drain spigot!!! Could I have damaged it with the sprayer?? Can I just plug the hole and go on?? Dang!!
Re: Radiator Problems
I have never seen this and I've had plenty of radiator issues. I would say yes, buy a plug and cap it off. The tanks are brass and the rest is copper, the copper normally goes first. I just bought a new radiator for my '69 and about puked when Orielly's price was $269.00, Autozone was $249.00...the radiator shop we use to repair radiators on the forklifts...$189.00. Needless to say, I could have bought an aluminum cheaper than the parts stores, I bought the $189.00 radiator and all is cool, literally!
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
Active Member
Actually the radiator you have is sort of desirable since it has the trans cooler in it. If you ever decide to get an automatic, you need it.
I would suspect someone may have used radiator stop leak in it before and by flushing it, you may inadvertantly flushed the sealer out. Take it to a radiator shop and have them look at it. They unsolder the sides and will patch it for you and check for any other leaks. It's not as expensive as you might think. I had mine done couple years ago for $40.00. Totally cleaned and vatted, the leak fixed and pressure tested and painted. |
All of the radiators I have seen, being either manual or automatic have the tranny cooler. This may only be on the replacements..I don't know?? The problem with his is if he did have a automatic his transmission would be flooded with coolant. He probably has a pretty large hole in it.
i've spent so much time and money on radiators that turned out to be unrepairable or short lifespan repairs that i generally will go for a new radiator and quit all the trips to the shop and multipule fillups with antifreeze and the days in the shop . i feel its alot cheaper in the long run when you're dealin with cheap less than $200 radiators, if it were something exotic that was 500-700 to replace i'd be tryin to fixer up
^ I agree.
#7 | ||
![]() Join Date: Nov 2001
Agree... Quote:
Most all aftermarket radiator, regardless of M/T or A/T have the trans cooler in them... I would take it to a Radiator Shop, if they can't fix it, then... If you'd like to purchase a NEW 3 row or 4 row radiator. here are what I can sell them for... Modine 366 - 3 row $187.50 SHIPPED TO YOUR DOOR Modine 369 - 4 row $212.00 SHIPPED TO YOUR DOOR *above prices are shipped within continental USA Any questions at all, feel free to PM me OR call 605-341-6634 M-F 8-5mt *these are special "Board-Only Prices"
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
That is a damn good price shipped to your door for a 4 row and a Modine.
Thanks for all the replies!!!! I have just purchased a 4 core radiator from Autozone for $179.00. Initially, I was just going to insert some threaded plugs to solve the problem. I figured it would be a temporary fix because the radiator appears to have been fixed (poorly) in the past. I figured I would buy new and move onto my next project and hopefully not look back. The Stop Leak is a great theory. I hadn't thought of that. I'm sure glad I didn't have an automatic transmission hooked to it!! Thanks again for the feedback
Damn Yankee
most A/M distributors carry just the AT rads to reduce the number of unique SKU's they have to carry. The MT rads are still made but harder to find
Between Trucks...
A few years ago I was driving my '72 LWB across country, down in San Antonio my radiator started to leak. I hunted down an Autozone in Universal City, Texas.
They were out of stock of radiators for my truck. I asked them for one for a '72 Caprice. It was a 3 row that fit for $99, and I was able to continue on to Florida...
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 08-31-2007 at 04:54 PM. |
#12 | |
#13 | |
#14 |
One of the First
![]() Join Date: Jan 2000
Old thread but looking for a Modine 369/ Dis the part number change?
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
