Old 08-31-2007, 07:35 PM   #1
cory321
Problem Child
cory321's Avatar
Replacing wheel studs
How do i replace the wheel studs on a corporate 14bolt full floating rear axle.The 78's lug nuts got loose and 6 out of 8 studs sheered off on the one wheel.Also if this isnt in the right section plz move it.
Cory
1972 gmc sierra grande
350/350 a/c soon`to get a new 350
I Survived Norwood
cory321 is offline   Reply With Quote
Old 08-31-2007, 09:58 PM   #2
earl87gta
earl87gta's Avatar
Re: Replacing wheel studs
I hate to say this but go to Pirate4x4 and in there tech section they have a break down of the 14blt axle you will need to pull the hubs out of it then press the studs out and press the new ones in dont use the lug nut tighten until they go in way it will just weeken the new ones and you couold end up right back ware you started.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 08-31-2007, 10:03 PM   #3
earl87gta
earl87gta's Avatar
here ya go hop this helps
http://pirate4x4.com/tech/billavista...ble/index.html
Earl
Old 08-31-2007, 10:10 PM   #4
cory321
Problem Child
cory321's Avatar
I think i will probably take it somewhere.Thanks Earl
I Survived Norwood
Old 08-31-2007, 11:44 PM   #5
earl87gta
earl87gta's Avatar
It not that hard at all just if you dont have a press I would take every thing apart and then take it to a shop and have them press the studs in with the cash you save you could do a disk break convertion while you have it apart.
Earl
Old 09-01-2007, 09:43 AM   #6
cory321
Problem Child
cory321's Avatar
I could do it myself but i dont think i will have the time between school and work.My 72s todo list is already pretty long
I Survived Norwood
