Old 08-31-2007, 08:58 PM   #1
goldengoat2
brake lines for my new axle
installing 77 3/4 ton axle in my 3/4 ton 67 this week , 77 brake hoses are 2-3" short, I ordered brake hoses for a 1 ton from napa they said they are about the right length (2.77" longer than the 3/4 ones) anybody out there with experience on this subject. o yea, it is lifted about 4"
65 tripower conv 4spd gto, 66gto, 67 gto
65 lemans conv 4spd
69 firebird conv.
67 c20 4x4
goldengoat2 is offline   Reply With Quote
Old 09-01-2007, 02:21 AM   #2
Mudder
Mudder's Avatar
Re: brake lines for my new axle
I got the stainless braided for mine but not sure what they were for.
Mudder is offline   Reply With Quote
Old 09-01-2007, 02:30 AM   #3
jamie72
jamie72's Avatar
i`m intereseted in this as i got a 70 3/4 4x4 with a corp 10 in the front i need to put new lines on..
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 09-01-2007, 06:25 AM   #4
zeeklu
http://inlinetube.com/ They will make any length you want and they were very reasonably priced. Chris
zeeklu is offline   Reply With Quote
Old 09-01-2007, 07:24 AM   #5
msgross
msgross's Avatar
jamie, if you have the corp 10 then be sure that your calipers are the same year too. The banjo bolts are metric on the newer (corp10) axles and calipers. Dana's had standard banjo bolts so I know the lines are different.
Might be best to get a set from a 4WD shop for a lifted rig...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-01-2007, 08:09 AM   #6
goldengoat2
brake hoses are due in on wednesday, i will post the results
65 lemans conv 4spd
69 firebird conv.
67 c20 4x4
Old 09-05-2007, 08:54 PM   #7
goldengoat2
update: the 77 1 ton brake hoses seem to be the right length for my disc brake conversion and a 4" lift on my 67 3/4 ton 4x4, frame attachment uses clips not the large cheep nut things
65 lemans conv 4spd
69 firebird conv.
67 c20 4x4
