Installing mufflers, does it matter which way?
Ring Ring, Longhorn man are you there!
I am installing new Walker mufflers on my 69 GMC. They are not marked with a direction flow. Does it matter which way the exhaust goes through them? They do have an 'A' and a 'B' each stamped on one end. I am thinking 'A' towards the front and 'B' end will have the exhaust coming out. Any thoughts?
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
Re: Installing mufflers, does it matter which way?
A before B makes sense to me. A in, B out.
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() |
the pipe diamiter should be just a little bigger on the front. front id should be the same as rear od.
common sense isn't so common anymore |
Pipe is the same front and rear, I measured with my calipers, 2 1/4 inch inside diameter.
They are Walker universal fit mufflers.
Universal mufflers are usually reversable. Are they round or oval?
Oval
