Old 08-31-2007, 11:12 PM   #1
wibilly
wibilly's Avatar
light switch
i just got my truck togather [not finished but togather] all lights working excepy dome and cargo. took it for a ride last night and just before i pulled in my neighbors drive way a headlight flashed bright .then without the engine running i turned them on to see if was still working and the other blew the same way. all other lights still work fine so i figured the dimmer switch shorted no wires seem to have gotten hot or anything. so tonight i put a known to be working dimmer switch and tw new halagen bulbs in and nothing ,still no head lights. i'm gussing it's the switch, maybe caused by a shorting dimmer or maybe it was the switch in the first place. what do you guys think? anything else i should check first? when the lights blew it acualy busted the glass on the filiment in side them on them both.
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 09-01-2007, 05:44 AM   #2
JimKshortstep4x4
Re: light switch
My guess is that the alternator was charging too high and blew both lights. The second light was finished off when you turned the lights back on.
I would start by checking the battery voltage and check the alternator output before turning on the new lights.
After that, you will want to trouble shoot the dimmer switch and light switch.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-01-2007, 05:50 AM   #3
cdowns
cdowns's Avatar
Re: light switch
i'd check for contact with bright shiney metal of your ground wires
Old 09-01-2007, 11:06 AM   #4
wibilly
wibilly's Avatar
Re: light switch
battery voltage with engine off is 13.27 engine running it is 14.6. all ground bolt holes were chased with a tap onreasembaly , straps were cleaned on wire wheele and new star washers were used. as i said all other lights and other accesarys were un efficted
Old 09-01-2007, 11:25 AM   #5
cdowns
cdowns's Avatar
Re: light switch
bolt holes for ground wires have little to do with grounding the electricial system you need to take sandpaper remove the paint under the lug on the wire for a good ground
