Engine Code Help
I am trying to figure out what engine I have in my 1970 C10 Custom. Numbers I got off front of engine by water pump are V1105TAX. Any idea what vehicle this engine came from?
Re: Engine Code Help
It is probably a 1970 engine but the casting date would be needed to confirm the year of the engine.
Here is the breakdown on the code you posted: V1105TAX V= Flint Assembly Plant 11= November, (month of assembly) 05= Day of assembly (No year is in the code) TAX= 1970 350 CID, w/4bbl carb, rated at 255 hp, with automatic transmission. The engine was used in C-10's as well as other series trucks. Engines with the TAX suffix were also used in 1972 model trucks. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Thanks!!! Where can I find the casting date?
The casting date is on the back of the block on the semi round part where the transmission bolts up. If your truck is 2 wheel drive, you may be able to see it behind the distributor looking down on the back of the engine. A mirror and flashlight can be used but the casting dates are hard to see.
Jim
