Old 09-01-2007, 08:24 PM   #1
cory321
Problem Child
cory321's Avatar
Transmission inspection cover
Will it hurt to drive my Truck with out the plastic inspection cover over the flywheel.Mine broke when i was installing a new starter.I will replace it but wanted to know if it would be ok without it.
Cory
1972 gmc sierra grande
350/350 a/c soon`to get a new 350
I Survived Norwood
cory321 is offline   Reply With Quote
Old 09-01-2007, 08:35 PM   #2
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: Transmission inspection cover
It wont hurt it just stay on the clean streets, and keep your fingers out
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 09-01-2007, 08:37 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Are you talking about the cover under the flywheel? Mine is metal so you must have a newer engine in it...
I see that yours is an automatic and if that's the cover you're are referring to it won't hurt to drive it like that. However, I wouldn't drive it on gravel and dirt roads unless you drive at slow speeds. Rocks may get kicked up into the flywheel and it may be possible to cause damage (its not very likely but you have to cover every possibility).
I have a manual and drove it for about 3 months on the highway with no problems until I found the cover.
If you replace the cover, let us know where you got it. I couldn't find one anywhere on the internet. Even tried GM parts and they no longer had it.
68gmsee is offline   Reply With Quote
Old 09-01-2007, 08:45 PM   #4
cory321
Problem Child
cory321's Avatar
Thanks. It will onl be on paved roads.I will have a new one in about a week.Also i was just going to arder a chrome one because i also couldnt find a factory replacemet/
I Survived Norwood
Old 09-01-2007, 08:56 PM   #5
mnunn454
mnunn454's Avatar
Yup. Keep the fingers out and you'll be fine.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 09-01-2007, 09:23 PM   #6
Aarons72s
I get them at the junk yard, plastic ones. I usually just walk thru the chevy section and pick one up. I have been getting them off of the 80's boxxy chevy cars or 70's and 80's trucks and vans.
As for running without it. No problem. My green and white one was missing it when I bought it. Ran for a couple years without one until I rembered to grab one from the junk yard.
Aarons72s is offline   Reply With Quote
Old 09-01-2007, 09:26 PM   #7
cory321
Problem Child
cory321's Avatar
The junkyards around here suck there is only one place that has pull-your-own-parts and it is about 15 miles from me.Any opinions on chrome ones from jegs or similar.
I Survived Norwood
Old 09-02-2007, 08:08 AM   #8
HomerJ
HomerJ's Avatar
I got one from Summit a few years back for my 400. It fits fine and was relatively cheap ($20, if I remember right). I ran mine without one for a few years - even on dirt roads, out in the woods for hunting, fishing, etc. I never had any problems.
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73
67 Chevelle SS Clone 454/TH400/3.73
HomerJ is offline   Reply With Quote
Old 09-02-2007, 09:24 AM   #9
68gmsee
Active Member
68gmsee's Avatar
Re: chrome ones.
I have an old GMC 250 three speed. No fancy stuff, just regular run of the mill farm truck in pretty good condition and I was looking for an original cover. No one makes a black one. I guess one can paint the chrome one.
I thought it would look too fancy for my truck.
Old 09-02-2007, 02:00 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Honestly... I've NEVER had one on any of my trucks. Daily drivers all of them, been driving them since 97 with about a 1 1/2 year break in the depressing lincoln days... never an issue.
