09-02-2007, 08:51 AM | #1 |
Never enough time!!
C-30 rear axle swap
Hey all, just picked up a 68 C-30 with a dump flat bed on it, but it has a slight bend in the rear axle from over loading I guess. Any ideas on what axles would interchange? I have an eaton out of a K-20 laying around here..are they the same? Or is the 1 ton axle heavier? Are newer ones able to be swapped in if I can find one? Thanks for any input on this subject, Gord
P.S. I will be hauling slab wood from a local Amish sawmill for firewood with it so it does get fairly heavy use |
09-02-2007, 07:55 PM | #2 |
Re: C-30 rear axle swap
install a modern 14 bolt. easy swap. 88 & up is best one
I BELIEVE IN JOHN 3:16 |
09-05-2007, 09:52 AM | #3 |
i would be looking for a 1967 or 1968 chevy truck one ton rear end
well i have too rear ends the one in my truck and the other if it dont work 1967 chevy one ton wrecker truck |
09-05-2007, 03:46 PM | #4 |
The 3/4 ton axle will have different spring perch spacing, but they are pretty easy to cut off and weld new ones on. A lot cheaper than buying a whole other used axle assembly. If your existing 3rd isn't messed up, then you can choose which gear ratio you want, if they're different.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
