Old 09-02-2007, 11:58 AM   #1
dooce
Difference in doors?
I've noticed that there are two different parts numbers for a new door depending if you have 73-76 or 77 and later. I've also noticed comments on people mentioning differences but never putting it in detail. Are the two doors interchangeable? I have taken a look at a set of 76 doors, and a set of my 86 doors and cannot find an obvious difference. Am I just not paying enough attention? I didn't think they would reproduce a different door for something so small, just like they don't produce a 79-80 specific hood (or not that i've seen). Please someone shine the light. Thanks DOOCE
1976 Chevy 1/2T 2wd SWB
327/Saginaw 4spd 3.73:1
LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071
LFSalleeII@gmail.com
dooce is offline   Reply With Quote
Old 09-02-2007, 12:04 PM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: Difference in doors?
might be trim related
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 09-02-2007, 12:42 PM   #3
f.monroe
f.monroe's Avatar
The 73-76 doors have a shorter door panel and a lot of the door is exposed on the inside . The 77 up doors use a larger door panel and they have provisions to mount the door panel . If you have a 73-76 truck and you buy later doors , you will be able to see the mounting points for the newer door panel style . If your truck is later than 77 , you can use any door shell you want but you will have to drill mounting holes in the door . The window regulator shaft is also shorter on 73-76 doors than on the later doors . If you are buying new doors , get the correct one for the truck you have . If you are looking for used ,complete doors , you probably want to get the same year doors also since the vent windows are a little different depending on the year as well as the thickness of the glass itsself . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 09-02-2007, 01:59 PM   #4
dooce
Is that all that is different? I remember somebody mentioning the top of the door or the door frame being slightly different? I don't need new doors, I was just curious. Thanks monroe
Old 09-02-2007, 02:16 PM   #5
bigblock73
yeller
bigblock73's Avatar
f.monroe nailed it, he is exactly right. Those are the only differences, the tops of the frames are the same.
bigblock73 is offline   Reply With Quote
