Flowtech Header ?
May have been asked before, but how good do the Flowtech headers for sbc fit on our trucks. Also, anyone used their ceramic coated ones? I found what looks like a good price for them and I have a $40.00 promotion code.
http://www.jcwhitney.com/autoparts/S...searchbtn.y=12
1997 GMC Sierra Ext 1965 Mustang |
![]() Join Date: Aug 2005
Re: Flowtech Header ?
I'm running a set of these. I put them in in February '06 and they have held up ok although my truck's not a daily driver. They've lost that nice shine they had but no rust as of yet (ceramic coated).
I remember one side needed some "modification" to fit; may have been the driver's side but nothing a couple of hammer wacks couldn't fix. Also, if you have A/C there is mounting kit sold separately that you will need to mount A/C bracket and header. |
Do they clear all the spark plugs and wires? Are the plugs fairly easy to get to?
#4 | |||
Union Electrician
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
Yes, but are they the ceramic ones. I have a set of Hedmans that fit like crap and have a hard time getting to the #5 and #6 spark plug. Had to dent them up to fit. Ask 70c10 about them....
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 09-02-2007 at 05:10 PM. |
sufficiently talented fool
![]() Join Date: Jun 2006
Steve, I have a set of the regular (painted) Flowtech headers on mine. I have not tried to pull a plug or anything yet, so I cant help you there. Call me and come by and check them out if you want to.
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
Between Trucks...
I had some regular painted Flowtechs, they fit well on my '72. No problems changing sparkplugs or anything. The only thing with them was that I had to use smaller headed header bolts to clear the tubes, I actually ended up using studs. I'd buy them again..
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 09-02-2007 at 07:00 PM. |
I have had a set on my 67 for about 6 years. They seem to fit pretty good. Plug #6 is blocked to the point that I have to use a wrench to get it out. The #5 tube bumps against the frame from time-to-time, but nothing that bad (probably specific to my install).
Overall, I think they're a decent value, but will go with Hedman Elite next time around. HomerJ
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73 67 Chevelle SS Clone ![]() |
PM sent
Still wondering about the ceramic ones. Anyone know if they are coated on the inside?
Aluminum slot wheels rule...
I bought some Dynomax headers, and after digging around the box I found a Flowtech exhaust sticker, so I assume they are reboxed Flowtechs, but anyway. I have no problems with them on my 68 4x4. The passenger side collector flange scrubs the driveshaft, but a little grinding will easily fix that. The plugs are pretty good to put in and take out, could be better but could be a lot worse too. But other than that I am very happy with them, both with the fitment and the quality. My friend bought some Hedmans for his Dodge 4x4, he hasn't put them on yet, but I wasn't impressed with the quality. I thought my Dynomax/Flowtechs were way ahead of them.
But thats just my 2 cents worth and my little experience with headers. |
Like a Rock!
I contacted flowtech 2 years ago and was told the inside is NOT coated to try to keep the cost down to the consumer. The headers are only 1.5" diameter as opposed to 1 5/8", so for performance I would go with something else.
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() |
