Old 04-26-2002, 10:24 PM   #1
Fast68Chevy
Fast68Chevy's Avatar
Post rolfmao ! the Big10/Heavy Half 12 bolt shafts are same length
lmoa! the big 10(2.75" wide brakes) 12 bolt axle shafts are same exact length as 70-72 12 bolt shafts! are all 31 3.8" long! lol!
cool deal
Randy- Lincoln, IL
r68c30@hotmail.com 2177353230
-71 C-10 350/CH465/3.07, assemble it, yeah right, that'll happen in this world,(not)
-84 Z28 Camaro 5.0L 700R4, 3.73, beater, paid way too much for it like an idiot,,
-84 Firebird SE 2.8L T-5, rod knocking, dammit,,
-82 Firebird 350 4bolt (TBL)/TH350, not running, dammit...
buy/sell/hoard/trade most any GM vehicle parts of any kind
-parting out: '81 Cutlass Supreme Brougham
*Paint is overrated
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 04-26-2002, 10:49 PM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
uhh cool? this dosnt help because those trucks already have 5 lug (expect the 70 duh)
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 04-26-2002, 11:21 PM   #3
Fast68Chevy
Post
yes, for 70, i know you arent too thrilled about it and think its useless info, but maybe someone else can use this info, and may be looking for shafts to get 5 bolt into their 70 axle and this would be a source for shafts, i know you see this as retarded and not as helpful info at all, im sorry
also would be good for 4x4 trucks converting to 2wd when wanting to go to 5 bolt, etc
i hope not all californians are so jaded when it comes to new info no matter how useless to them it may be,
Randy- Lincoln, IL
*Paint is overrated
[This message has been edited by Fast68Chevy (edited April 26, 2002).]
Old 04-26-2002, 11:57 PM   #4
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Red face
hmmmmm ok you took that wrong..... what i meant was it would be alot more useful if they were the same length as 67-69 shafts....
trust me must people in california are a helluva lot more jaded than me
on a similar note i recently found out 68 diff cover bolts are 7/16th length while 72 ones are 3/8ths
My Truck pictures
64ImpalaSS 327
[This message has been edited by 68SWB4x4 (edited April 27, 2002).]
Old 04-27-2002, 06:29 PM   #5
kaycee
kaycee's Avatar
Question
ttt So the only way to tell is to measure shoe/drum.What is an easier way to tell?And might I say that is some good info u all said
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 04-27-2002, 07:16 PM   #6
rodshop454
Post
As far as the shaft size goes I've been told by alot of junk yards, I'm sorry, Auto Recylcle centers, that only 71 and 72 axles will fit in a 71-72 rear end. Not true! I've used a posi, housing and all, just pulled the axles,from a 68 truck- with 72 axles. The 67 axles are shorter and won't fit. take both axles from a 6 bolt "68-70" drum and a 5 bolt axle and there the same length and seal diam. Just a little info I've found. Junk yards around here always want more for a 71/72 posi than they do for a 68-70 one and they will work!
1972 Chevy S.B.Pro street,1996 Z/28 Convertible,1989 Camaro Convertible,1967 Olds Cutlass Convertible, 2000 Monte Carlo SS
rodshop454 is offline   Reply With Quote
Old 04-29-2002, 01:49 PM   #7
ViperRed67
Post
I thought I would throw in that the 67-68 coil spring rears are narrower then the leaf axles. Also the 67 axle is about 1/2 inch per side narrower then the 70 up coil type to.
ViperRed67 is offline   Reply With Quote
Old 04-29-2002, 10:54 PM   #8
jason7627
Post
Does this mean I can swap the rears to 2.75" wide shoes by just swapping everything from the backing plates out?
72 lwb 468/th400/3.73 2/4 drop primer
jason7627 is offline   Reply With Quote
Old 04-30-2002, 12:24 AM   #9
Fast68Chevy
Post
i hear that it can be done to the 64-69 housings, yeah, i stil have yet to make time to do measuring on those housings and do a swap to see if it works sine i have a 78 model 2.75 brake axle here i parted the carrier out of, want to make it work on a 70-72 housing, but may be too wide, so hmm, crappy thast the 73-up shafts are same length as the 70-72 shafts, they may not be long enough to allow use of 2.75 plates and shoesa nd drum on 70-72 housings, cant see why it owuld work if housings are acutally longer in 70-72 than 73, which i believe are, i need to measure that width at the axle tube flanges directly at where the paltes bolt on to the flanges,
i noticed that the 2.75 brake plates have alot more offset than the 2" ones, so hm ,tat may make up for it and it all may work fine on any housing, that would be wild.. never know..... 2.75" shoes upgrade would be great
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
*Paint is overrated
[This message has been edited by Fast68Chevy (edited April 30, 2002).]
Old 04-30-2002, 07:07 AM   #10
mrein3
mrein3's Avatar
Post
Last spring or the spring before da-burb stood on dry ground and handed me wrenches while I was rolling around in the mud pulling the rear axels out of a 75 or 76 4wd Blazer for my 1971 4x4 chassis. They bolted (slid?) right in and are in use to this day.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 04-30-2002, 11:05 PM   #11
jason7627
Post
Fast68Chevy, seems to me if the axles are the same length, then they should fit. Wouldn't be suprised if the backing plates are offset to make up for the extra width. I've got a '72 1/2t that I would love to put the big shoes on, heck of alot cheaper than discs.
Old 04-30-2002, 11:53 PM   #12
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
mrein, thats wierd ive always heard the axle pad spacing is diffrent, hopefully my 14 bolt will slide right into my 68 4x4....
My Truck pictures
64ImpalaSS 327
Old 05-01-2002, 09:00 AM   #13
ViperRed67
Post
Heavy half?? Whats really funny is when I was in the Air force we used long bed 1/2 ton 4x4 trucks and blazers. They were rated as 3/4 tons. Same trucks as the street versions, just a tad more in the heavy duty department such as tranny coolers and some different frame bracing here and there. But they still ran the 12 bolt axles..
