Old 09-02-2007, 09:23 PM   #1
70chevroletx-cab
Problem may be solved.....
I have been having a problem getting the roof line just right on the extended cab project that I am working on. It is close be not really what I wanted it to look like. Thanks to the part that I picked up from "Uncle" yesterday, my problem may be solved. With some work of course.
70chevroletx-cab is offline   Reply With Quote
Old 09-02-2007, 09:54 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Problem may be solved.....
And somewhere theres a convertible suburban....... That should fix the roof area of the crew cab..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-03-2007, 07:57 PM   #3
Hart_Rod
Hart_Rod's Avatar
Keep us update, can't wait to see how it comes out.
Hart_Rod is offline   Reply With Quote
Old 09-03-2007, 09:42 PM   #4
Frizzle Fry
Frizzle Fry's Avatar
I hope you use the square cornered sub front doors and rounded rear doors
Frizzle Fry is offline   Reply With Quote
Old 09-04-2007, 05:22 PM   #5
70chevroletx-cab
At this time I only plan to make an extended cab without any doors on the rear.
Old 09-04-2007, 05:35 PM   #6
shifty
Questionable
shifty's Avatar
Tim's a good guy, sells at good prices. and this is a project i'm going to keep my eye on, looks pretty cool!
i like that you're going with a sub top rather than two standard cabs. i think the two-cab merge trucks look pretty crappy. this one should turn out pretty good.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 09-04-2007, 05:45 PM   #7
Hart_Rod
Hart_Rod's Avatar
How much of the top do you plan on using? I might need what you have left.
R
Old 09-04-2007, 08:05 PM   #8
70chevroletx-cab
R
I cut the sub top off even with the back door, leaving from the rear window back.
Old 09-04-2007, 09:52 PM   #9
Hart_Rod
Hart_Rod's Avatar
is that part straight? If so, I might need part of it to straighten out some stuff on my crewcab.
Old 09-05-2007, 08:12 PM   #10
70chevroletx-cab
The metal on top is real good. There is some rust behind the driver side window area. I still may have to use the part that rolls down at the back to match up the back of my cab.
Old 09-05-2007, 10:37 PM   #11
Hart_Rod
Hart_Rod's Avatar
I need a piec about 35" wide to go in the marked area below.
Old 09-06-2007, 08:14 PM   #12
70chevroletx-cab
You do know that the roof line on the suburban is different from the trucks? It is taller with a different line down the side above the drip rail.
Old 09-06-2007, 08:44 PM   #13
GREASEMONKEY72
GREASEMONKEY72's Avatar
nothin good ol fashioned work cant solve, cant wait to see the outcome
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 09-06-2007, 08:50 PM   #14
Hart_Rod
Hart_Rod's Avatar
It will be easier making that one work than making one from scratch .
Old 12-11-2007, 06:14 PM   #15
70chevroletx-cab
I finally got a little more work done on this project. It has taken a while, but the top is starting to come together.
Old 12-12-2007, 12:47 PM   #16
Hart_Rod
Hart_Rod's Avatar
Looking good! You need to post more pictures, . How much of the roof do you have left?
R
Old 12-12-2007, 06:28 PM   #17
70chevroletx-cab
R
I still have the whole rear half.
Old 12-12-2007, 07:10 PM   #18
Hart_Rod
Hart_Rod's Avatar
I need a section about 3 feet wide if you want to get rid of it.
Old 08-16-2008, 10:27 PM   #19
70chevroletx-cab
Progress has been slow on this build but hopefully that is about to change. I just ordered a set of suburban doors from GMCPauls. When they come in I will be able to see how much more work roof has left and get the b piilars put back together. Then things should move along a little faster.
Old 12-13-2008, 12:15 PM   #20
70chevroletx-cab
Here is a picture of the progress so far. It has been a slow go but any progress is good progress I guess.
