Old 09-03-2007, 12:37 PM   #1
72chevy327
stock spindles
whats the prob with chopping the springs and running stock spindles im looking for around a 4-5" drop. will there be alot of bump steer can it be corrected. iv seen people slam there trucks by only torching the springs and getting a wheel alignment but iv heard bad things about the springs loosing there tinsel strength when they are heated. i was also contemplating airbags can they be run with stock spindles. thanks Quinn
72chevy327 is offline   Reply With Quote
Old 09-09-2007, 10:21 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: stock spindles
If you cut 1 round off the bottom of the front springs, you will have tween 2-3" of drop......& thats just about max on a spring drop (to keep good front geometry). Best bet on the lower drops , is a spindle/spring combo, or go with a spindle/ bag combo . You could run bags with stock spindles, but wont get the front to align properly if you go much more than 3" as ride height. L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
