Old 09-03-2007, 01:17 PM   #1
pdr510
Junior Member
pdr510's Avatar
Fuel filler idea?
I have looked at all the ideas on the board for fuel fillers for a fleet side. I like Hugger's tail light filler. The only problem is I am not going to have chrome around my tail light. So there would be a gap on the bottom of the light that I would not be able to cover up. I like the idea of the side marker light filler and the filler on top of bed stake pocket, but I don't like having to cut up a new bed side. With all that being said, I am tossing the idea around to fill from the bed floor. I found a gas filler on ebay that may would work. It is angled where I could have a straight shot into the filler neck of the blazer tank. Here is some pics of the filler from ebay and my bed floor. Tell me what you think.
1970 C-10 Fleet Side
Gen IV 6.0 with 4L80E
pdr510 is offline   Reply With Quote
Old 09-03-2007, 02:37 PM   #2
wibilly
wibilly's Avatar
Re: Fuel filler idea?
i personaly don't like the fillers in the bed floor.i like to use my trucks,and i also think it's the easy way out, although i have seen som real nice craftsmenship on some. i do understand not wanting to cut a new bedside but if done well it is worth it. i did a sidemarker fill on my shortbox and love it. i finialy got to try it yesterday and it fill as fast as the pump will pump
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 09-03-2007, 03:05 PM   #3
Bowtie001
Project underway - finally.
Bowtie001's Avatar
Keep in mind that with the filler on the bed floor, you won't be able to fill with stuff in the bed - it could get annoying.
1972 GMC Pre-resto... awaiting allocated funding.
Bowtie001 is offline   Reply With Quote
Old 09-03-2007, 03:09 PM   #4
71swb4x4
71swb4x4's Avatar
I had the sidemarker fill on my truck and I loved it. Just extend the rear stake pocket enough to hide it and most people would never even know it was there.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-03-2007, 03:18 PM   #5
chevyboy55
chevyboy55's Avatar
I agree with the above posts. Also any dust, dirt, leaves & general crap laying in the bed floor might fall into the filler hole?
Great minds think alike,So do ours
chevyboy55 is offline   Reply With Quote
Old 09-03-2007, 11:45 PM   #6
yenko427
yenko427's Avatar
I have the filler in the side of the bed. Its from a 90 chevy s10 and the old filler neck has been teared drop to put a power antenna in. I hope this helps.
yenko427 is offline   Reply With Quote
Old 09-03-2007, 11:56 PM   #7
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I used one from Hagen Streetrods welded in to the bed side and also did a power frenched antenna where the old filler was.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-04-2007, 12:21 AM   #8
ofnaman
ofnaman's Avatar
I have the aftermarket side tank on my truck with the ugly aluminum fuel door on the side of the bed. I was going to put the filler for that tank on the inside of the bed, basically directly on the other side of where it is now. After noticing the tank sits lower than the chassis, I will not be using it anymore, but I am going to be putting a rear fuel cell in the truck and am going to put the filler in the rear on the inside bedside.
ofnaman is offline   Reply With Quote
Old 09-04-2007, 01:26 AM   #9
cstm68
cstm68's Avatar
i used the same style filler in my bed floor.
there are some pics in my build thead
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 09-04-2007, 08:12 PM   #10
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Fillers in the bed floor aren't my cup of tea, but I have seen some I like. If your bed floor is wood (I know it isn't), there is a vendor who makes a kit to enable a bed board to flip up to allow access to the filler. When the bed board is flipped back down, nothing shows. Bed is still usable but be sure you don't need to get any gas while it is being used.
Member Nr. 2770
Old 09-04-2007, 08:33 PM   #11
rob32472
who sells the wood floor filler you spoke of?
rob32472 is offline   Reply With Quote
Old 09-04-2007, 09:33 PM   #12
pdr510
Junior Member
pdr510's Avatar
I am also going to experiment with a s-10 fuel door hinge to use on the tail light. This may eliminate the need to add extra clearance for the tail light to swing out. I just need to trim the door back where it will fit. The hinge itself is narrow enough to into the taillight opening.
Old 09-04-2007, 09:42 PM   #13
Ironhorse
Ironhorse's Avatar
I went a different route for my under bed tank. Very little hassle and works quite well at the pump. Never have had any back flow issues and the bed floor is available any time.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 09-11-2007, 07:30 PM   #14
crzngmychvy
"1972 C5"
crzngmychvy's Avatar
What I did...
- 72 2wd Blazer ...sold...
2wd Blazer Page
crzngmychvy is offline   Reply With Quote
Old 09-12-2007, 03:16 AM   #15
Mudder
Mudder's Avatar
In twelve years I have never had a problem with the filler in the corner of my bed floor......Here's another option. The gas nozzle will go through the gas cap. You do not have to remove it to fill tank.
The last pic is mine.
Mudder is offline   Reply With Quote
Old 09-12-2007, 09:46 PM   #16
gringoloco
A guy with a truck
gringoloco's Avatar
tried this based on Wynne's setup and could not make it work without trimming the same area he did. Curious to see if you can figure it out. I think you will need a 'double hinge' type for it to clear properly.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-12-2007, 11:05 PM   #17
pdr510
Junior Member
pdr510's Avatar
I believe you are right. The light opening is just too tight.
Old 09-12-2007, 11:17 PM   #18
Johnnyreb
Johnnyreb's Avatar
gringoloco good to see a fellow coonass where about in shreveport?
Heavy Chevy
Johnnyreb is offline   Reply With Quote
Old 09-12-2007, 11:35 PM   #19
jugernot
Life, Be In It.....
jugernot's Avatar
I have a step side bed and this is what we came up with
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 09-13-2007, 03:59 AM   #20
gringoloco
A guy with a truck
gringoloco's Avatar
Broadmoor
-Chris
