What year tilt column???????
I have a tilt column that I pulled from a 67 Chevy but it has a GMC horn cap, so I am thinking it is not original.
How can I tell what year truck it came from?
Mike 1989 C1500 SWB Reg Cab 2003 Chevy Tahoe Z-71 70 Camaro RS/SS - 454 |
Desert Rat answered a similar question here.
http://67-72chevytrucks.com/vboard/s...threadid=25689 Tilt did not come in 67 so I may be a correct tilt with a 67 steering wheel with GMC cap or it could be a van column with a different steering wheel. Check the length of the shifter arm... if it appears short it will be van column possibly, also check the lenght of the shaft coming out the bottom also... if its about 5 inches long its a van column also. Neutral safety work?
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
