Old 09-03-2007, 03:34 PM   #1
cell
Active Member
cell's Avatar
I made a test rig for my HEI
So I am in the middle of swapping my points for an HEI distributor, and I was having some trouble getting any spark out of the thing. So, I took it all apart and set up a test rig for it. The test rig works great (I guess I just had a loose wire initially), so I took a video of it and put it up on youtube:
http://www.youtube.com/watch?v=ufSoBODtk9Y
I'll probably post again later describing the setup in more detail in case anyone else is interested.
cell is offline   Reply With Quote
Old 09-03-2007, 06:49 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: I made a test rig for my HEI
Interesting... Needs better lighting, but it looks like it served your purpose.
Wouldn't be a bad idea to explain what you did and how you did it, in case someone needs to test one out of the engine.
68gmsee is offline   Reply With Quote
Old 09-03-2007, 08:19 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Thanks for posting your info, but me doing anything related to that just wouldn't work. But let us know how you connected everything. I have an HEI distributor that has a bad wire to the pickup coil, that I want to fix for the experience.
Member Nr. 2770
Old 09-03-2007, 08:50 PM   #4
57sailplane
57sailplane's Avatar
lol man i never thought of that. that really is a good idea the reson im laughin is were the test took place...
57sailplane is offline   Reply With Quote
Old 09-04-2007, 12:22 AM   #5
Morgsie
This is all you need to test an HEI dist:
Put it next to the dist, and pull the trigger, if the solder gun makes noise (vibrating, etc.) you're pickup coil is gone. If not it's probably the module.
Morgsie is offline   Reply With Quote
Old 09-04-2007, 12:26 AM   #6
72cheyennesuper20
72cheyennesuper20's Avatar
Good idea.
72cheyennesuper20 is offline   Reply With Quote
