Active Member
Lca ?
I have a 68 and am looking for some LCA's do I need them from a 68 or will 67-72 work?
Thanks Jack
68 Chevy Long utility bed. Now swb/Bagged Soon to be 468 (Maybe 496) BB/Turbo 400 |
Re: Lca ?
The 67-72 arms will work just fine. The only difference may be the ball joints (depending on which year the arms come off of). There are a few different ball joint sizes and tapers from 63-87. If possible I would try and locate some 73-87 arms... they are a better design (IMO) and the parts for them are readily available and a little less expensive. Another thing I would recommend is replacing the u-bolts, that hold the arms to the crossmember, with the later model u-bolts (73-87). The newer u-bolts are a 9/16 diameter, so you will need to drill out the holes in the crossmember to accept them. The design was "upgraded" for good reason!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
True Addiction
Re: Lca ?
Action, I've got a set if your interested. Also have the tops, and stock crossmember as well.
