brake pedal will not come up
i am working on a 71 i bought a new master cyl and brake booster
i used a old perportion valve. the pedal wont come all the way back up with out help should i adjust the rod going to the master cyl or buy a new valve? |
sufficiently talented fool
![]() Join Date: Jun 2006
Re: brake pedal will not come up
Check the bellcrank assembly behind the booster. Spray it with WD40 and work it some and see if it helps. You may even have to remove the pin and clean it up, then re install it.
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
Dave's not here, man
How tight is the nut installed on the bolt that connects the booster linkage to the pedal? It only needs to be tightened enough to allow the cotter pin to be installed.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
did you bench bleed your new master
common sense isn't so common anymore |
