What are these spacers for?
Sorry for the bad pix....these spacers are about 3/4" OD 3/8" ID and 3/8" thick. There are two of them. I saved them for a reason, but age is kicking in here.
![]() Might they be spacers for the alternator bracket or possibly the power steering bracket? Thanks Brian |
Active Member
![]() Join Date: Jul 2007
Re: What are these spacers for?
Are they metal? Looks like spacers for the alternator or power steering pump. I've seen them, but don't remember either.
I have some spacers that look similar for a gasket one on of my quadrajet carbs but they are a hard plastic. |
These spacers are metal. I have a hunch like you said that they are for the alt or PS, but not too sure at this point. I know the spacers you are talking about for the carb gasket. In fact I think they come with the carb gasket. These are not those.
![]() Join Date: Mar 2003
They are for the alternator bracket when changing the water pump-----long water pump design. The spacer goes between the water pump and the lower bracket hole
Between the alt bracket and the wp? I have seen these and there is usually only one. That is also the later model alt bracket design when the alt is on the passenger side. I have not taken any of those apart. I have been collecting parts for the earlier design with the alt on the other side....so I'm not sure that solve my mystery.
