Old 09-03-2007, 11:44 PM   #1
Brock
upgrading to an older model
Brock's Avatar
From this to this...so far
I bought my truck off ebay for a whopping $242. Its a '68 stepside short box very little real rust, just the rockers, door corners, and inside the cab above the drivers sunvisor (how'd that get there?), and some surface rust. It has the I-6 and a 3-OTT, I don't know if either of those works but it looks like the engine has been open (no carb) for quite some time. Here's what it looked like when I picked it up in BANDANA, KY...right down the road from Monkey's Eyebrow?!?
68 stepside, short-box, multi-colored (for now)
Brock is offline   Reply With Quote
Old 09-03-2007, 11:48 PM   #2
Brock
Brock's Avatar
Re: From this to this...so far
After a bunch of sanding, red oxide primer, sanding, grey primer, sanding, and a little trim paintinghere is wher it is today...Still waiting on a driver's side rear fender and a couple of odds and ends. I bought a 307 off a guy that was replacing it with a 350 for $20 and a guy at the racetrack gave me a 700r4 tranny, its gonna be canary yellow with black trim. I Can't decide on rims and tire combo's so any suggestions would be appreciated
Old 09-04-2007, 12:26 AM   #3
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Looking Good so Far, Can't Beat the Price you Got it For.............
Good Luck, Rick
toomanytoyz is offline   Reply With Quote
Old 09-04-2007, 01:01 AM   #4
HeavyD
HeavyD's Avatar
Slots or TT2's get my vote.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 09-04-2007, 05:59 AM   #5
L0WRIDE
L0WRIDE's Avatar
great progress
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 09-04-2007, 09:31 AM   #6
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by Brock View Post
..., just the rockers, door corners, and inside the cab above the drivers sunvisor (how'd that get there?
Good beginning.
If it's going to sit for a while, seal the drip rail channel (name?) with some sort of sealer. Some times the old factory sealer cracks and lets water seep under it and it is a good entry point for rust on the top of the cab....
68gmsee is offline   Reply With Quote
Old 09-04-2007, 09:47 AM   #7
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I see you installed the "in-cab,reverse rotation Turbo system " already....good job!
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 09-04-2007, 10:10 AM   #8
Brock
Brock's Avatar
HeavyD---What size wheels and tires do you suggest?
BobbyK---That "in-cab reverse turbo vortex thingy" was one of the first tools I employed right after the hand lift I used to remove the seats (which were mounted on a plywood frame that wasn't bolted down) and the shag carpet.
68gmsee---Any advise on how to seal the drip rail channel? I thought about just cleaning it out real good and filling it with bondo and blending it back into the cab. I'm sure there are less invasive approaches.
Others---thanks for the comments
Old 09-04-2007, 10:27 AM   #9
RustyParts
RustyParts's Avatar
Nice Progress "Brock", I live right down the road from you in "Beech Grove".
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 09-04-2007, 11:35 AM   #10
Brock
Brock's Avatar
I've been there a few times...had two girlfriends in highschool from the big town of Beech Grove. Small world huh?
Old 09-04-2007, 11:45 AM   #11
RustyParts
RustyParts's Avatar
Sure is, getting smaller everyday.
Old 09-04-2007, 12:09 PM   #12
68gmsee
Active Member
68gmsee's Avatar
HeavyD---68gmsee---Any advise on how to seal the drip rail channel? I thought about just cleaning it out real good and filling it with bondo and blending it back into the cab. I'm sure there are less invasive approaches. Others---thanks for the comments
On my work truck I did just that. I cleaned out the channel (scraped and used wire wheel) bondo'ed to reform a smooth surface, primed and painted.
On my other truck, I just sealed it with clear silicone sealer used for exterior gutters. I did this as a preventive measure since it was starting to crack and I know it's going to be a year before I paint it.
Old 06-22-2011, 11:03 PM   #13
Brock
Brock's Avatar
Well its been FOREVER since I've done anything to the truck. I got into Dirt track racing and time and $$$ were both running low. However, I'm just about tired of racing so I'm back on the truck. Here are some updated pics. New wheels, tires 255/60(I bought them to go on the racecar...better served on the truck), got carpet installed, built a frame for the seats & got them in, built a console, moved the fuel tank out of the cab (put a 15 gal tank in the bed). Made some tailgate chains. It runs now, tomorrow it might even move.
Lets see if I can get some pics uploaded now
Old 06-22-2011, 11:11 PM   #14
Boog
laying low
Boog's Avatar
Welcome back. Inside is looking a whole lot better. Outlaw wheels are cool too.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-23-2011, 02:14 AM   #15
Rooster's 67
Rooster's 67's Avatar
four years have treated the ole truck well. Glad to see her gettin some love again.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 06-23-2011, 10:49 AM   #16
Brock
Brock's Avatar
Thanks, its been a journey.
OK here's the story...My Brother-in-law has a transmission shop here in town. We made a deal, I'm more of a wood worker and he's more of a mechanic, so I'd build him a deck around his pool/He'd get the truck running. He got the motor and tranny in then kinda stopped on it since I hadn't got it licensed yet...well I wasn't getting it licensed until it was somewhat driveable so theres the first roadblock. Its been sitting in his shop since. When his business was slow he'd start tinkering with it and WHAM he would instantly get busy (hence we call it the "work truck" because everythime he started working on it he'd get paying jobs). There is the second roadblock. In the mean time I started racing which took most of my time and money, Third roadblock. Now I'm prettymuch done racing, and I'm focusing on get the truck going.
Old 06-23-2011, 11:14 AM   #17
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
stay at it looks alot better than before!
John
1999 Toyota Tacoma 4x4
Old 06-23-2011, 12:54 PM   #18
1972RedNeck
1972RedNeck's Avatar
I love American Racing Outlaw II rims.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 06-23-2011, 03:48 PM   #19
Brock
Brock's Avatar
Thanks. its on the rack right now and I was sitting looking at it and REALLY noticed how good they look. These were affordable to...they are 15x8 with the centercaps/lug nuts/valvestems/mounted/balanced the whole set cost $367...I was pleased. One of the wheels that came on the truck is a steel version I'm gonna clean it up and polish it for a spare.
Old 06-30-2011, 10:34 PM   #20
Brock
Brock's Avatar
BIG changes comin' as soon as I can get some pics...its no longer multi-colored. Actually look pretty good for a driveway paintjob. Its got a few bugs...I posted in the body/paint board asking how to deal with those, does anybody here have any advice on making the critters not quite so visible?
Old 07-01-2011, 05:44 AM   #21
yuccales
yuccales's Avatar
That things looking WAY better! Keep posting pics of it's progress.
yuccales is offline   Reply With Quote
Old 07-01-2011, 10:28 AM   #22
Brock
Brock's Avatar
OK its daylight so picture time...these don't really do the yellow justice. I think the sun kinda screwed with my camera. Anyway here ya go.
