Problem Solved - Bad Fuel Filter!!!
Well, I posted this original issue of trouble on a road trip a while back...
http://67-72chevytrucks.com/vboard/s...ormance+issues So this weekend after another 3-hour trip pulling the trailer, and experiencing similar (but worse) symptoms, I thought of checking the fuel filter (at the campground) and whalla!!! She was gunky. I didn't think seriously of it before, 'cause it was only a couple of months old. But I guess the new fuel pump along with the fact that I drew a tank down to the bottom caused a sudden blockage. A friend of mine told me this had happened to him before as well, right after changing out a pump. The newer, more powerful pump will pick up sludge in the tank that the previous pump left alone - go figure. So, I managed to pick up a new filter at the small town where we were camping, and all is well. The return trip was a breaze. Here's a photo of the culprit... Last edited by Zilverado; 09-04-2007 at 09:15 AM. |
Cruzzzn' Vet
Re: Problem Solved - Bad Fuel Filter!!!
Good catch Z-man
#3 | |
![]() Actually I still have the filter in the back of the truck - I'll cut it tonight. Great idea. I'm curious to see as well. I'll post a pic if it's worth it. |
The Crazy Machanic
thats good and i agree canada has some clean air.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) ![]() * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one ![]() |
So, I got around to cutting the filter tonight and found this. I'm just guessing, but I imagine the sand isn't original equipment.
Spear and magic helmet!
Wow!
-- Will |
WOW, that much sand fit in that little filter!
Mike Email: Click here to email me -- 2019 Silvedrado 4x4 1970 Chevy 3/4 ton, 396BB, on air bags |
Yeah, it surprised me too. Actually, the pile in the picture is pretty shallow, but needless to say, it's a fair amount of crud - about 1/2 teaspoon. Just imagine what might have happened if the filter hadn't caught it. No wonder that the engine was not getting the necessary fuel.
The question is - - how did all this crud get into my fuel tanks??? |
If your getting sand in there from a possible hole on top, then there may be water getting in. The truck I bought about a month ago, wasn't running properly, that is one reason the owner sold it and bought a newer truck. Anyhow the tank was fiberglasses at one point and ended up letting go allowing water to get in, since the sending unit lines up great with the gap between the cab and box. Anyhow I had a good 1/2" -1" of water in the bottom of the tank.
I thought the fuel was supposed to flow from outside to inside???
Sand may be from your friendly local gas station's tank. |
#11 | |
For the most part, I fill up at a brand new local station near my place that has only been in operation for a short time. While it's not completely impossible that the sand came from their underground tanks, I suspect the residue has been sitting at the bottom of my tanks for a while - just waitng for the new (tighter/more powerful) fuel pump to just suck it up. Either way, I'll be keeping an eye on the filter until I am convinced there fuel is clean. |
Cruzzzn' Vet
HOLY Sheeet!!!
#13 |
Flat Black, & Chrome!
wheres the fuel filter located i think i wanna check mine now...
#14 |
#15 |
This one is inside the front of the carb - just where the steel fuel line from the pump goes into the carb. The fuel line 5/8" "flare nut" unscrews from the filter fitting, and then a larger wrench is used to unscrew this fitting from the carb. The filter is in behind that. Simple.
#16 |
![]() Join Date: Jun 2007
I started having the same problem with my truck too. Stalling, dying, sputtering, acting like it's starving for fuel, having to floor it to get going and to keep speed up.
I bought a new fuel filter and fuel pump for mine last weekend but haven't put them on yet. Plan to do that this weekend to see if it clears up my problem. After seeing this post I think I'll just try the fuel filter first and see what happens. I don't know when the last time mine was changed....if ever. Fuel filter is easy to change. It's located at the end of the fuel line where it goes into the carb. Disconncet the fuel line from the carb, then unscrew the big nut on the carb that the fuel line attaches to. The fuel filter is right behind it. ...Joe
I'm not speedin'! I'm qualifyin'! |
