Outlandish Trends - FL
Getting ART arms - what spindle?
Hey, I've got bags front and rear and am going to be getting ART upper/lwr arms. I will be getting new drop spindles so my question is which should I get and which will work on my setup? I have a 6-lug disc conversion up front. Anything particular I need to know before I order? Also, what is your preference and why: Belltech 3" or ECE? Is there really much difference between the 3" and the 2-1/2 from ECE?
-Bret 67 short-fleet sold! |
Re: Getting ART arms - what spindle?
Get the correct spindle for your 6-lug brake conversion. I believe they're based on 73-up spindles but it's better to verify that through the manufacturer. FWIW, it's easier to find stuff for 73~87's.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-04-2007 at 11:34 AM. |
#3 | |
#4 | |
Call one of the vendors. See if they can confirm the 6-lug kits are basically re-drilled 5-lug rotors & if they're 73 & later or???? Other than that, the easiest way might be to get an outer tie-rod for 71-72 & 73-up to test fit on your current spindle. Which ever tie-rod fits should tell you what you need to know.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-04-2007 at 04:54 PM. |
A guy with a truck
Measure the thickness of the rotor- if it's 1.25", use the Belltechs. The 6-lug conversion rotors are just HD blanks drilled for 6-lug.
They are not a full 3" from what I gather, but they are more than a 2.5" ECE. The 73-87 parts are also cheaper/more readily available. Can't go wrong with either for quality. I've got Belltech on the truck and ECE on the Blazer. Since you're swapping everything- use the Belltechs- my .02.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
thanks guys, I'll measure tonight and go from there. I'll post up some pics with my new digicam also to see if it helps you guys to see what I have.
gringo, it is 1-1/4" wide. What do you mean by "HD blanks"?
A guy with a truck
'Heavy Duty' These are the rotors used on 71-80 or so, then GM made them optional and introduced a light duty 1" thick rotor. Most aftermarket kits are based around the HDs- they just buy them blank and machine for 6-lug instead of 5. If this is the case with your set-up, the Belltech 3" will work.
-Chris
ok, so I can order the Belltech's for the 73-87 trucks and balljoints for same? Do I order arms for 73-87 also then? It's a lot of money to drop all at once so I want to make sure I'm getting the right stuff.
A guy with a truck
Yep. The ART arms come loaded(cross-shafts, ball joints) so you won't need joints, but you will need inner/outer tie rods.
Do you have drop spindles now? What kit is it?
yeah, but have no idea what brand they are. There are no markings on them that I can see.
