Old 09-04-2007, 12:03 PM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
How bad is slipping tranny affecting mpg?
My third gear in my 69 turbo 400 is slipping. I am only getting 8-9 mph with rebuilt carb and stock 350. I do not know rear gears and am running 31" tires.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 09-04-2007, 12:07 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: How bad is slipping tranny affecting mpg?
I guess mine is slipping, too. These don't get great gas mileage but a slipping tranny will probably have other symptoms than poor mileage.
Mine AIN'T slippiing and my mileage isn't much better. I put $10 in it every month, whether or not I drive it. It always needs it and it hasn't moved. Got a locking gas cap, too.
Anyway, I changed out the flex hoses from the pump to the carb and the gas smell/leak went away. Should be better, now.
Member Nr. 2770
Old 09-04-2007, 12:34 PM   #3
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
A lot of folks on here are claiming 15 mpg some higher some lower and
I thought with a quadrajet and keeping my foot out of it 12-15 was realistic.
I hope it will be with a new tranny if not I may have to keep my new truck and sell the 69 to pay for the 72.
Old 09-04-2007, 01:13 PM   #4
Chances are with 31" tires your speedo/odoemeter is offg also, so you are probably getting better mileage than you think. Gearing & the type tranny (slipping or otherwise) play a factor also. Obviously with a non-overdrive tranny you'll get worse. A turbo 400 does worse than a T350 because it tanks more to run the tranny...Again it may be small, but it does add to the overall mileage.
Old 09-04-2007, 04:19 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
42% of the ppl responding to my poll http://67-72chevytrucks.com/vboard/s...d.php?t=172346 claimed 10 - 12 MPG.
If your tranny is slipping, there's no way of tellin how much extra fuelit's burning.
Why do you think it's slipping?
Old 09-04-2007, 04:54 PM   #6
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
It does not shift properly in drive. It shifts ok manually. It is the original tranny w/140k mi and the truck sat for 14 years. I also had one go out before and it would act similar.
Old 09-04-2007, 05:10 PM   #7
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Thanks Lonhorn Man just looked at you poll that make me feel like I can improve a few mpg.
