Old 04-29-2002, 06:36 AM   #1
skyhawk1
skyhawk1's Avatar
Post Carb problems? Maybe?
I recently bought a 72 Suburban that's in overall great shape. I've installed a new HEI dist., new fuel pump and an Edelbrock 600 with electric choke. It's been starting and running great. However the last two or three mornings it won't start. After nearly running the battery down each time, I can pour a little gas in the carb and she'll fire right up and run and start good all day. (the Edelbrock is only a couple of months old)
"The World's a Mess"!
71 C-10
72 Suburban 2WD
Oceana, West Virginia
skyhawk1 is offline   Reply With Quote
Old 04-29-2002, 07:14 AM   #2
MikeB
MikeB's Avatar
Post
Before you try to start the engine the next time it's cold, make sure the choke closes when you open the throttle. Also, are your plugs in good shape? I've seen engines that run well, but have cold start problems due to old plugs.
MikeB
69 C-10 Fleetside, mild 383, Dart Iron Eagle 180cc heads, Crane Energizer 266 cam and 1.6 roller rockers, Edelbrock Performer manifold and 600cfm carb, HEI w/ MSD components, 1986 front spindles/disc brakes, Vintage Air in-dash.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 05-01-2002, 05:03 AM   #3
skyhawk1
skyhawk1's Avatar
Post
Thanks, I did remove the air cleaner this morning and moved the throttle and it closed. Started right up. Must have been a glitch in the electric choke.
71 C-10
72 Suburban 2WD
Old 05-01-2002, 08:51 AM   #4
Slick1
Post
Not a glitch, that's the way they work. every morning when you start the truck, yoiu need to "preset" the automatic choke. the way you do it is to press the accelerator all the way to the floor once, then release. Now, your choke is set, and you can start 'er up.
Slick1 is offline   Reply With Quote
Old 05-01-2002, 11:36 AM   #5
COBALT
COBALT's Avatar
Post
Yeah, that's pretty common for most of these old automatic chokes. Especially the old Rochester 2bbl and Quadrajets. I'd run my battery flat every day with that old 2G unless I set the choke using the throttle. lol
You can do it by hand as well (just to see how the mechanism works). Just get in there and pull the throttle assembly all the way forward until it "clicks". You'll be able to see how the throttle plate, linkage, and all that stuff adjusts to allow your carb to run rich at idle when you're starting your truck.
'69 3/4 ton C20 2wd w/ 350ci/400THM and a wood bed!
'69 3/4 ton Custom 20 2wd w/ ORIGINAL 350ci/4sp Manual and a wood bed (parts beast).
Seattle, WA.
*See pics of my trucks and project at www.webshots.com!
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
