Old 09-04-2007, 04:15 PM   #1
firemedicsafd
firemedicsafd's Avatar
Remote start
Does anyone know how to or how hard it would be to install a factory remote start for my 01 silverado? i know it cant be too hard. I know the dealer will charge an arm and a leg for it. Any help would be appreiated. thanks!
firemedicsafd is offline   Reply With Quote
Old 09-04-2007, 05:00 PM   #2
zacut
67 chevy SWB Fleetside
Re: Remote start
Don't know about a factory remote start, but I have installed several including one in my 04 Avalanche. It is not too difficult. The hardest part for me was to route the main power wires through the firewall to the terminal below the distributor. If you are familiar with what it takes in general that helps. Simplified you need to tap into the parking light and horn circuit, into the starter and two ignition circuits and into the tach signal. You also need a second device that is model specific that will bypass the passlock security feature and will plug into both the starter and the OBD2 plug. This box will also enable the power door locks on the new key fob. It took me about 4 hours. I would plan on longer if this is your first. Also make sure the remote starter kit comes with a wire color diagram for your vehicle that tells you what color wire you are looking for and where to find it. This will make life fairly easy.
Good luck.
67 Chevy C10 Short Wide
350/350 ... Front Discs ... ECE Lowered 2.5/4
Vintage Air ... Oak Bed Floor ... Painless Wiring
Brothers 1 pc Windows ... Lokar Pedals, Shifter, E-brake
Ididit Column ... VDO guages
zacut is offline   Reply With Quote
Old 09-10-2007, 09:38 AM   #3
djracer
djracer's Avatar
Re: Remote start
an 01 doesn't need anything funky for the locks just 03 and up! If your factory remotes work well you can use them! You just hit lock twice to start! I can get you the stuff (either way) and a print out for 125 shipped and provide technical help to install! I have been in the bus. since 1986!
Kevin
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-10-2007, 03:17 PM   #4
firemedicsafd
Re: Remote start
what stuff will be needed? can you give me a list of the required stuff? how hard will it be to install? Thanks for the help. i will also be doing the remote start thing for my 06 trailblazer and i know that one might be more difficult. thnaks for your help!
Old 09-10-2007, 04:14 PM   #5
djracer
djracer's Avatar
Re: Remote start
all you need is the remote start module and a bypass for the factory antitheft! It doesn't look too bad! I'll include a print out of the wires you connect to and their location!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
