Old 09-29-2002, 02:42 AM   #1
firstgencamaros
Question Later model front suspention?
Hello all....
I was told that 73 - ~76 chevy 1/2 ton front control arms, disc brakes, etc will bolt right on to the 67 - 72 pickups. Has anyone else heard of this? If so would this be a cheaper/better way to do a disc brake conversion?
Thanks,
FGC
firstgencamaros is offline   Reply With Quote
Old 09-29-2002, 05:32 AM   #2
Burlinator
Just Another Crazy Canuck
Burlinator's Avatar
you will also need the front crossmember and engine cradle to get them to fit
its almost a direct bolt in jsut a couple holes in the front( I think) need to be grinded out a little
1985 454/465/205, 38.5x11-16BOGGERS
soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI
Burlinator is offline   Reply With Quote
Old 09-29-2002, 04:06 PM   #3
crazy longhorn
Fabricate till you "puke"
I did the swap on my 69 longhorn several yrs ago, before there were any bolt on parts. I used 75 spindles & rotors,& had to use the balljoints & outer tierods for the 75. The lower A arms used were 71-72(steering stop differences). you will no doubt run into problems with the center link,inner rod ends,& sleeves on your 68 going this route. as a rule, try to pull the pcs off the same truck,& you should be in good shape. good luck, & if any troubles midswap,feel free to E mail me & I will try to help out........Crazy Al
crazy longhorn is offline   Reply With Quote
Old 09-29-2002, 05:16 PM   #4
Dean23
68cst_ss490
Dean23's Avatar
I used a front crossmember froma 79 pickup for my 68. Easy as pie, you just need to oblong two holes and drill 2 others the rest bolts right in. Way to easy.
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 09-29-2002, 05:23 PM   #5
1-PU70
1-PU70's Avatar
I did the swap on my 70. Used parts from a 77. You can use up to a 87. Ony differance is they went to metric in 80. You dont need engine cradle or stuff like that . You need upper and lower control arms with ball joints and spindals. Tie rod ends and center link. Thats it. I didnt need to drill any holes or make any oblong. Just a streight swap. Good luck. Oh ye if you go to power from non power I think you will have to dimple the frame if the frame is 69 or older.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 09-29-2002, 07:39 PM   #6
Johngear67
The Mighty Blue Bottle
let us know of any problems you hit
1967 Chevy C 10 Custom
350 780 cfm 467 lift 278 dur
ported&pollished
2400 stall 350TH
B&M shifter
175 shot of nitrious
Johngear67 is offline   Reply With Quote
Old 09-29-2002, 07:59 PM   #7
Reumster
L.E.D. Freak
Reumster's Avatar
firstgencamaros
Drop me a e-mail. We need to talk.
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
