Old 09-04-2007, 11:43 PM   #1
ABLAZN
Oh..never mind....
ABLAZN's Avatar
Question Newer steering gear box advantages ?
It seems like I have heard that there is some advantages to using the '73 in up steering gear boxes.If so, what are they? I have one off a 1988 Suburban with a drop pitman on it that I can use if the effort is worth my time. I may need to change it anyhow, ever since I changed my wheels and tires, It seems to wander more then I noticed before.
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
MORE TO COME !!!!!! Now going to 2WD!!!!!
Sold.
I got it back after 22 years and did not even know it !!!
THE STORY HERE
Project Low Down Dirty Rat
ABLAZN is offline   Reply With Quote
Old 09-05-2007, 12:45 AM   #2
old man jimmy
Re: Newer steering gear box advantages ?
Don't know of any advantage using burb steering box. But I think you have a quicker steering than the burb which I would keep. As for your wondering, you might try replacing your drag link. Seems to be the weak link in the front end of the beast. I only use 33's, and get road wander about every 5 years or so. New drag link & good as new.
old man jimmy is offline   Reply With Quote
Old 09-08-2007, 11:18 AM   #3
pumpkin
pumpkin's Avatar
The newer boxes have a qucker ratio, but you some times loose a bit of turning radius. The boxes with quicker ratios also usualy have different fittings. O rings rather than the double flare.
pumpkin is offline   Reply With Quote
