BB motor mount ?
I have a bb with 72 only mounts and stands,but the frontend cross member is off a 72 that came with a sb, and the stands when set on the frame and cross member, there is only 3 of the four holes in the frame and cross member. Can I just line up the other 3 and drill the 4th hole in the cross member...... Thanks Jason
72 Cheyenne Super 80 Silverado Blazer 2wd Last edited by sameyrasmea72; 09-05-2007 at 06:13 AM. |
Re: BB motor mount ?
Show some pictures and you'll get a better answer.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
I mounted a BBC in my 72 using 73-87 SBC towers and it was a similar situation. I drilled the fourth hole and put a bolt through it, but I considered solid welding it to the x-member.
It should work fine either way
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
