MuscleRodz LED Tail light troubles
I know I have seen postings about this before, but I can't seem tofind them when I search. I just bought some LED Tail lights from Mike at MuscleRodz. I have read on here before that you do not need the electronic flasher for these lights. So I installed the first one, no problems. Works fine. I install the second one and now no tail lights at all. So I went and bought the electronis flasher. Still nothing. I even tried putting everything back to the way it was before I had the LED tail lights and they still do not work. Any help would be greatly appreciated since this is my daily driver.
Thanks in advance, Rick |
member #16
![]() Join Date: Dec 1999
Re: MuscleRodz LED Tail light troubles
Sounds like a blown fuse.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Fuse looks fine. I even tried a new one. I only checked the one labeled "tail stop". Is there another one I should check?
check the bulbs in the front blinkers ive had this problem and the bulbs were bad in the front
nickle and dime |
Checked them, and they are working.
its all about the +6 inches
what's not working, the tail lights? The flasher has nothing to do with tail lights.
Correct, the tail lights do not work now.
Old Skool Club
![]() Join Date: Jun 2001
Sounds to me like a combination of events, like a bad/missing ground on that side; a corroded socket; a broken wire on the light socket assembly or anywhere between the switch and the taillight assembly. If you want to be sure that the LED's are working/bad, put it in the other side. I'm gonna bet it is good and you have the other options to check out.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Tried to put it on the other side. Does not work, nothing works at all now. Sockets look fine.
Dr. Frankentruck's Monster
![]() Join Date: Aug 2007
You may have shorted the harness during installation or the ground may not be as good now. Brainstorming.
If you have not already, take a test light and check for power. Start at the fuse, then work your way down the harness. At least this way you can figure out if the problem is in your rear wiring harness or if the rear wiring harness is even getting power. Again, I am brainstorming. I have no professional automotive electrical experience. But remember, electricity runs in circles. So think of big complicated interconnected circles.
I'm not prejudiced, I hate everyone. Project SLOMO http://67-72chevytrucks.com/vboard/s...d.php?t=430494 |
Junior Member
musclerodz?? Got a link?
going to sell this one...looking for a SWB project next. |
#13 |
71 rustless in texas
Try taking and plugging them in the front. You said the front lights work right? It's the same bulb so you should be able to plug them in and see if they work in the front.
"The secret to creativity is knowing how to hide your sources." "No one really listens to anyone else, and if you try it for a while you'll see why" ![]() 71 C-10 LWB presently in a perpetual state of disassembly '96 Toyota (my work car) '04 Mustang Convertable (wife's car & other money pit) Latest aquesition and why my trucks still in the garage covered with junk.. 2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck FAQ here VENDORS here SUPPORT THE BOARD here My second favorite SITE |
#14 |
I will try that. Is there only one fuse for the tail lights and the parking lights?
#15 |
theyre $30???
on scotts theyre like...$200 |
#16 |
SKINNY TIRES RULE!
I installed the Musclerodz taillights without any problem. I'd guess that you have a bad wire someplace in your system. You might have dislodged a weak connection. I'd pull the tailight bucket that caused the problem and see what you can see.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#17 |
Self-proclaimed LED man
On their website they say that their led's are only rated for 7.7-14.0 volts. Im not sure if you guys have ever put a voltmeter on your tail lights, but i have and i know that they go up to 14.6volts (this may vary from vehicle to vehicle due to the original adjustable voltage regulator). This may cause a problem.
Justin
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once ![]() Norwood Survivor Last edited by 724x4a/cchevy; 09-05-2007 at 09:43 PM. |
#18 |
sufficiently talented fool
![]() Join Date: Jun 2006
My guess would be a bad ground. I believe the grounds for the rear lights are behind the rear side marker lights. I have a set of the LED taillights from Musclerodz, and love them!! Check for power at the light sockets, then check the grounds.
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
#19 |
My truck is a 67, no rear side markers...
#20 |
Questionable
check for power at the tail light themselves to see if they're getting power.
mike has been great with me in the past, and i'll be doing business w/musclerodz again in the future. have you given him a call yet?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#21 |
No one has called yet, so if there is an issue with the lights themselves, I NEED TO KNOW!!! I have sold probably close to 100 sets of just the 67-72 lights and someone will eventually have a problem. We are dealing with 40 year old wiring and they usually will work perfect right up to the point where you change something. The voltage range is not the issue. My first guess is the socket is not making good contact with the plug. Make sure you have voltage at the socket. Check the lights themselves with a battery. If they don't send them back (you will be credited) and I will replace them. I have sold several hundred units over the last 6-8 months and out of those I think I have only returned one set.
Mike Redpath Last edited by Musclerodz; 09-06-2007 at 12:01 PM. |
#22 |
I'm just not sure what happen. Everything worked fine before I installed them. Now the old setup dosen't work. I'm trying some things. I'll let you (Mike) know.
#23 | |
![]() Join Date: Nov 2004
![]() I have LED's I bought from PickMup (don't know who makes em) but I love 'em. A guy at work even commented how nice they look (and how bright they are) just today!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 09-06-2007 at 01:33 PM. |
#24 |
Junior Member
Ordered mine today
#25 |
I checked the new lights and they are fine, nothing wrong with them. Something happened when I plugged them in. After everything stopped working I checked to see if there was power to the rear, none. I just ordered a new wiring harness after finding where I think the problem is.
Thanks for all the help. MuscleRodz (mike), I hope it didn't sound like I was saying something was wrong with the lights. If it did was not meant to sound like that. If I thought there was something wrong with them I would have called you. Just was trying to see if anyone had this happen to them also. Your service was great. Rick |
