Old 09-05-2007, 05:12 PM   #1
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Question about dropped A arms?
Hi Guys, many years back I had a '68 C10 that I put SoLow dropped A arms on. It worked well and had no issues with them.
I don't see anyone doing this anymore. Why? Reason I am asking is I can now build my own based on the same setup that SoLow used. I am looking to graft a '70 C20 ball joint mount onto my C10 arms so I can use '96 ball joints to work with the '96 spindles. Basically building my own disc brake swap using GM factory parts so I can get replacement anywhere. It also allows me to us either a 5 lug or 6 lug rotor without changing anything else, so if I change my mind on what wheels I want.
The brake info I got from this site on this post, http://67-72chevytrucks.com/vboard/s...ad.php?t=35042
I have the '96 spindles and '70 C20 arms but the shafts in the arms are wasted. My C10 arms are fine, hence wanting to use those.
I guss if anyone can tell me if the outside diameter of the '96 ball joint is the same as a '64 C10, then I could just swap joints and nothing else.
Hope this makes sense. It does in my head.
L8R,
Mike
chevy_mike is offline   Reply With Quote
Old 09-06-2007, 04:55 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Question about dropped A arms?
Why not just swap the shafts?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-06-2007, 09:53 AM   #3
chevy_mike
chevy_mike's Avatar
On one of the arms, they managed to split the area where the end cap screws into. Never seen someone do this before. Since you have to thread the cap on I am not sure how easy it would be to fix.
Old 09-06-2007, 06:56 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Just grab some out of the JY for almost nothing. The 3/4 ton arms continued into the 73-up body style.
-Chris
Old 09-07-2007, 06:03 PM   #5
chevy_mike
chevy_mike's Avatar
It's just a PITA to get down to one and hope I find what I need, especially since I have the parts I really need.
I guess I my question is, Why does no one use dropped A arms anymore?
Old 09-07-2007, 11:11 PM   #6
jlaird
jlaird's Avatar
no one uses dropped a-arms because dropped spindles are made which are a better option when it comes to steering geometry. Also, unless the dropped a-arm is built a certain way, you will have clearance issues if your suspension is really low. With that said, I modified my stock arms to be a dropped a-arm, but did not make the cup any lower than the lowest part of the stock arm.
jlaird is offline   Reply With Quote
