Old 09-05-2007, 06:28 PM   #1
48 ish
48 ish's Avatar
Big Block Trees
Can someone tell me why I need to change the trees when I pull the small block for a big one?
hooberjon@yahoo.com
"Life's Been Good To Me So Far"
1941 Chevy PU (new project, right out of the field)
1948 P/U: 350/700r4, Nova Clip,Chevelle rear, air ride suspension, custom door handles, custom firewall, custom dash, buckets and console, visor
1967 C20: 427 Tall Deck, Turbo 400 with Gear Vendors aux tranny, 5th wheel, 3500 bucket seats and console.
1996 Geo Tracker 2x4
1996 Geo Tracker 4x4
48 ish is offline   Reply With Quote
Old 09-05-2007, 06:57 PM   #2
JAKES 68GMC
Aluminum slot wheels rule...
Re: Big Block Trees
Whats this "tree" your talking about?
JAKES 68GMC is offline   Reply With Quote
Old 09-05-2007, 07:06 PM   #3
71tahoe
71tahoe's Avatar
Re: Big Block Trees
Motor towers where the motor mounts to the frame and front Xmember?
SBC towers weren't designed for the monster torque of the BB maybe? Same reason you don't find a TH350 behind any BBC from the factory. I would also say the external dimensions are accounted for in the big block towers. Let the fan line up with the rad. shroud, keep the valve covers out of the firewall and brake booster.
I won't say you can't use them because someone probably already has and has solved these problems.
71tahoe is offline   Reply With Quote
Old 09-05-2007, 07:08 PM   #4
ratrod67
ratrod67's Avatar
Re: Big Block Trees
Exhaust clearance.
Weight distribution.
ratrod67 is offline   Reply With Quote
Old 09-05-2007, 07:25 PM   #5
cdowns
cdowns's Avatar
Re: Big Block Trees
maybe so the engine will fit with the proper driveline geometry// why do you think gm spent a bunch of money designing individual parts for
Old 09-05-2007, 07:45 PM   #6
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Re: Big Block Trees
The SB "Trees" have a smaller stump. Seriousy you need the BB "Trees" to make the exhaust fit right. Useing SB towers with a BB your stock Exhaust Manifolds will hit the frame and I think you have problems with Headers also
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 09-05-2007, 09:16 PM   #7
Classic Bowties
Always on the hunt...
Re: Big Block Trees
48 ish: Hello, feel free to call again any time to discuss these Small Block to Big Block conversion concerns. Cb
Classic Bowties is offline   Reply With Quote
Old 09-05-2007, 10:12 PM   #8
Bob Moore
Re: Big Block Trees
48ish - you could definitely use the stronger BB parts especially since you have been buying the "tall deck" goodies to put out even more power and torque.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 09-06-2007, 12:56 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Big Block Trees
strength isn't the issue, it's fitment. The main reason is for exhaust pipe space.
However, a secondary reason, would be so the fan is located properly in the shrowd.
