Old 04-30-2002, 08:25 AM   #1
1968GMC
love my truck
1968GMC's Avatar
Post ford starter relay
I read a while back on here that somone instaled a ford starter relay to clear the wires from tuching the headders. Can somone tell me how t wire this? I have a HEI egnition. I was comming home from work last nite at 2AM when sudenly my starter engaged itself so I pull over to shut the engine off and it wont shut off. You should here that. it sounds like someone is doing a brake stand(at 2AM nice)talk abbout panic. After 2-3 minutes the starter quit(its dead) and now wont start. I'm thinking one of the wires touch one of the headder and f%$&ed all up.
1968GMC is offline   Reply With Quote
Old 04-30-2002, 08:40 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Post
Here's a pic of the Summit remote selenoid that I installed. It is the same as the Ford selenoid I am told.
Also, here are the instructions for the selenoid.
1969 C20 4x4 with roughly 6" lift and 35's
residing near Rose Hill, Kansas
Yukon Jack's Web Pages
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-30-2002, 09:46 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
The wires hitting the headers would not do what you explained.The #1 reason to do the ford solinoid would be to stop the hot start issues.
Who ever designed these starters was sniffin glue. The solinoid gets hot, and will not work. Mount it up high, and the problem goes away. (it is still possable, but highly unlikely).
It sounds to me like you had a wre short out with another hot wire under your dash...maybe the large hot on your starter and the purple wire wore through and made contact.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 05-01-2002, 12:37 PM   #4
1968GMC
love my truck
1968GMC's Avatar
Post
I found my probleme, it was the cable from the battery to the starter, loose conection at the starter. Thanks guys for your help.
