Old 09-05-2007, 09:17 PM   #1
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Question Zero rate add-a-leafs??
Not sure what exactly is a zero rate add-a-leaf. Would this cure my problem of my rear tire on my 4x4 being closer to the front of the wheel well than the rear?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 09-05-2007, 11:31 PM   #2
cobinder
Everything is work in progress
cobinder's Avatar
Re: Zero rate add-a-leafs??
Turbo, check out this link it should tell ya everything you wanna know about it. I bought one from these guys and it's good quality stuff.
http://www.offroaddesign.com/catalog/Zero%20Rates.htm
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 09-07-2007, 06:31 AM   #3
Zero-rate is a fancy name for a block,IMO.Zero-rate spring?That`s a spring that doesn`t do anything for your suspension,just sits between the axle and spring.That`s a block in my book.I`m not bashing them.All it says to me is a small block (like an inch) is ok as long as it`s longer and kept stable from shifting.Blocks up front are taboo,so just call it a zero-rate spring.
Old 09-07-2007, 01:11 PM   #4
1969K10
1969K10's Avatar
They call it a zero rate add-a-leaf, because you take out the center pin of your leaf spring pack, add this piece, and bolt the leafspring pack together. It can't (?) blow out like a lift block might on the front axle.
And yes, it will help move your axle back in the wheel well opening. It has (3) holes, centered, 1" & 1-1/2" offset, IIRC.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 09-07-2007, 08:25 PM   #5
msgross
msgross's Avatar
depends on your U-bolts but you might also need the top plate that has multiple holes for the center pin as well. I bought new leaf perches for my axle which has the other holes, so I might move mine back as well.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-09-2007, 04:40 PM   #6
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Thanks guys for all the info. Just ordered some of the zero rate blocks/leaves for m Offroad Design. Hopefully they will work.
