![]() Join Date: Jan 2002
Is it possible?? Ebay auction???
Was front positraction axle an option in 1972?? Look at this blazer on ebay
http://cgi.ebay.com/ebaymotors/1972-...QQcmdZViewItem
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
Insert Title Here
Re: Is it possible?? Ebay auction???
4 wheel drive would be all 4 wheels, sooooo in a sense it would be a posi fron and back, no?
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
There is a member a little north of me with a 69 K20 that has factory 4:56 lockers front and rear so I would assume you could get front posi as a option..It would be listed on the glovebox if dealer installed.
Yep, posi was option..it was typically in the ratio 3.73 in 1/2 ton dana's or 4.56 front of the dana in 3/4 tons.
Jamie Hyneman is my twin
![]() Join Date: Nov 2005
My 67 has front posi. here is the glove box label.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
the only reason i asked is cause i have NEVER seen front positraction on a spid label, and all the posi pickups i have ever seen have only had rear positraction. thanks for the input
Recovering Truck Driver
I can't remember the option number, but the "no spin" option called for a Detroit Locker in the rear, and I've been told the Detroit Locker in the front axle was a dealer installed option. My 67 K-20 has both lockers in 4.56 gears. It also has a little decal behind the seat above the tank that explains a little about the lockers.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
I have seen several SPIDs posted here over the years that list front limited slip. It was definitely a factory option.
Tim |
He shows the glovebox label in his auction pictures. If you look carefully on the left side 4th line down it says posi traction axle and on the right hand side on the very bottom it says frt. axle posi tract.
www.fatdaddieshotrods.com |
I don't think these trucks had factory "lockers" up front...at least I've never seen that. Rear, yes. A positraction, or posi, is NOT a locker.
What I am curious about is what type of posi the factory unit is. Power or track lock?
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Born Psycho
![]() Join Date: Feb 2001
i had a 71 chevy 1/2 ton 4x4 with front posi from the factory, option number on my glovebox was 9501AA. that axle is now under my 72 super.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
