Old 09-05-2007, 10:06 PM   #1
chevykevy
chevykevy's Avatar
Wiring Harness Woes
I am putting together a 68 short box. I recently picked up a GMC cab that is a 4 speed cab with wiring harness. I am putting in an automatic and automatic steering column. The fuse block doesn't have the wiring to connect the neutral safety switch or reverse lights. I also have a fuse block from an automatic cab with warning lights. I am putting in a cluster with gauges, not dumby lights. Can I splice the two together some how or should I start shopping for the correct automatic harness with gauges and wiring for the column?
chevykevy is offline   Reply With Quote
Old 09-06-2007, 12:08 PM   #2
Musclerodz
Re: Wiring Harness Woes
yes, if you can't find used, we can supply a new one.
mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 09-06-2007, 12:29 PM   #3
Bob Moore
GMC Paul has a very easy to follow conversion from lights to gauges. You should not a problem following it - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
