BlahBlahBlah
Spindle and rotor question
Ive only changed my mind back and forth a million times on my panel project. I purchased everything to switch from drums to 6 lug disks and dropped spindles. This is all CPP stuff.
Another board member has decided to switch his conversion from 5 to 6 lug. Will his new stock 5 lug rotors work on my CPP spindles and will my CPP 6 lug rotors work on his stock spindles...Im thinking all should swap fine, just wanna make sure before we go any further. Mark |
67-72 Addict!
Re: Spindle and rotor question
Mark, I'm pretty sure they are not interchangeable. Here are two part numbers on Paul's site:http://www.gmcpauls.com/67-72_d&s.htm
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 09-05-2007 at 10:50 PM. |
"Trucks with Class"
![]() Join Date: Jul 2000
Yes...they interchange perfectly!
BlahBlahBlah
Thanks guys...since PICKMUP is my vendor Im gonna go with what he's posted. Hey Frank if you look back at this thread would you mind PMing me what I paid for these and Im gonna need the price on the rear axles too now...
![]() Last edited by CG; 09-06-2007 at 12:28 AM. |
67-72 Addict!
I didn't realize they were the same. I learn something new everyday!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
