Old 09-06-2007, 02:15 AM   #1
ThatOneBlue67
I survived Dead Man's Curve.
ThatOneBlue67's Avatar
front lowering coils
If I were to use 2" front drop coils on my 67 1/2 ton, would I need to buy shocks? Will the ride be crappy if I don't? Will I break something if I don't? Just wondering ifI can be a cheap skate or not
I'm thinking about just cutting the coils really... $114 is too much for lowering coils IMO.
"The people should not be afraid of their government. The government should be afraid of it's people."
"The Hurricane"
1967 Chevrolet C10
350 Eight Cylinder, 700R4 BowtieOverdrive
Cherry Bomb... Disturbing the Peace Since 1968.
ThatOneBlue67 is offline   Reply With Quote
Old 09-06-2007, 06:55 AM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: front lowering coils
Go ahead and cut a coil, you'll be fine with stock length shocks unless yours are already worn out.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-06-2007, 06:56 AM   #3
63 & 64 Bowties
and a few others
don't know if this helps, cause this is a 63....But, I cut my front coils 2 rounds, cut off the stop mount on the lower control arm, and kept the original shocks.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 09-06-2007, 07:14 AM   #4
71tahoe
71tahoe's Avatar
ART provides stock shocks with their front bag kit and it goes WAAAAY lower than 2".
71tahoe is offline   Reply With Quote
Old 09-06-2007, 08:28 AM   #5
68gmsee
Active Member
68gmsee's Avatar
No problem with stock shocks. I lowered mine in front 2-1/2 inches some years back and haven't had any problems.
68gmsee is offline   Reply With Quote
Old 09-06-2007, 08:41 AM   #6
aventur1
aventur1's Avatar
71 LWB. So if I buy a good set of lower coils, will the ride be the same as original? With the shorter coils are they designed to have the same rideability? Both front and back? 2" in front and in back would be great!
Sounds like a easy way to lower? And keep stock shocks or no big deal to buy shorter shocks front and back.
aventur1 is offline   Reply With Quote
Old 09-06-2007, 08:51 AM   #7
hgs_notes
GEARHEAD
hgs_notes's Avatar
I bought 3.5" drop coils many years ago and love the ride. I had to cut out the stops on the lower A arm also. The stock shocks were fairly new then, and are still on it. I don't drive it that much either. If I were to notice the shocks not working, I'd replace them with ones for dropped trucks, just because. 2" is hardly noticable on these trucks visually, and depending on what tires you run, you might consider dropping it more so the tire fits the wheel well better. With my 3.5" drop, I can still haul a full load without problems. The coils I bought had the same sping rate as stock so the ride was about the same. I am running 235/70/15's front and 275/60/15's in back. I would put some 1" or so lowering blocks in back of mine too, but want to check my clearances first so I don't have any problems.
hgs_notes is offline   Reply With Quote
Old 09-06-2007, 09:01 AM   #8
aventur1
aventur1's Avatar
Ya, your right 2" is not enough. So is there a board vendor that carries the
3"+ coils for front and back? I want to keep the slight rake look so will go with the same front and back,Not sure about wheels and tires yet. I know I don't want the low profile tires, but would like to go with larger rims, what ever will fit after it's lowered.
Old 09-06-2007, 09:26 AM   #9
68gmsee
Active Member
68gmsee's Avatar
Re: ride comfort... My truck seemed to have improved in handling. Didn't notice any difference in comfort level.
All tall vehicles will improve with handling if lowered to a reasonable height. There is less sway and more control on curves due to the lowered center of gravity thing. If you go too low, then you may encounter other problems.
Old 09-06-2007, 02:09 PM   #10
hgs_notes
GEARHEAD
hgs_notes's Avatar
You may want to rethink your order of operations here. Wheels and tires are way more expensive than the springs. And which ones you get will may a difference on how much you want to lower it.
A good idea is to get the wheels and tires you want, measure the bumper to ground and tire to wheel well clearance, then cut your front coils until you get the ride height you want. Re-measure and then order the coils to get that ride height or just keep your cut coils, depending on how low you went. If you keep them as cut, drive it a while to see if you like it. You may decide to replace the spindles instead.
