Size Matters
Is my balancer seated?
OK experts....How do you know if your harmonic balancer on your 350 is fully seated? I used the center bolt and a washer to pull it on and it went most of the way but I think it may need to go a little further. The bolt started getting harder to turn and I started getting concerned about breaking the bolt so I stopped. The crankshaft also started turning which leads me to another question...What's a good way to hold the crank so you can torque the bolt properly? Any tips would be greatly appreciated.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ![]() ![]() |
Recovering Truck Driver
Re: Is my balancer seated?
If it is a used balancer, just check to see if you can see any of the shiny surface in front of the seal, if there much at all, it's not in far enough, pull the bolt out and check the threads both on the bolt and in the crank.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
It's a catastrophic success.
![]() Join Date: Jan 2003
Look for the timing cover seal mark, also pull the center bolt, shine a light and see if the end of the crank is pulled up solid.
I think that you need to use a special tool like this:
#5 | |
Size Matters
Can't look for the shiny surface...I put a repir sleeve on the balancer. It's all shiny!! Doh!!
Size Matters
ttt
Pull it back off and measure the depth as how far it can go on, then put a mark on the balancer shaft and reinstall. Make sure and use an installer or you might rip the threads out of the crank.
Sierra Grande Club
I just used an installer on my balancer install (a AutoZone loner), and turned it until it stopped. The end of the crank wasn’t at the end of the balancer though..
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() Last edited by Sport/Truck; 10-04-2007 at 08:12 PM. |
blood type; Retumbo
I use an installer just like the one pictured (mine is a little more elaborate though) and hold the flywheel with a flywheel turning tool. a screwdriver stuck in the teeth and jammed against the starter will work as well.
the balancer bottoms against the timing gear. do NOT use a hammer to install it, bad for thrust bearings. do NOT use the bolt either, those threads are meant to HOLD the balancer in place. if they get damaged the balancer can come off and wreak havoc on all kinds of expensive parts. |
#10 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
I hope the main bearings are seated well to stay in place.
Sierra Grande Club
No doubt! So you need to use common sense when these people offer there advice.
![]() s/t
#13 |
![]() Join Date: Nov 2002
+1 on using the installation tool.
I'm with Ram-Man, take it back off and take some measurments. Reinstall it. I realize that most people probably don't use a torque wrench, but it will help make sure - along with proper use of the installation tool - that you don't damage either the bearings or the damper itself. BTW, using a hammer cannot only damage the thrust bearing, but it can damage the bond of the rubber to the inertia ring and the damper center. If the inertia ring slips, at best you set the timing wrong (and possibly damage the engine) or, at worst, the slipped ring causes engine failure due to messed up harmonics in the engine rotating assembly (read that: broken crankshaft).
Jeff '67 short Fleet; my ongoing project. '66 long Fleet; my original "baby." Live life or bust trying. |
#14 |
Size Matters
Thanks for the info guys. I will remove, measure and reinstall this weekend.
#15 |
![]() Join Date: Mar 2003
How about a visual------something as simple as the crank pulley lining up with the water pump pulley.
#16 | |
Size Matters
