Old 09-29-2002, 04:18 PM   #1
Johns70
Johns70's Avatar
desktop dyno help?
i need some help and was wondering if some with it could run my engine to see what it is making? somthing is fouled up,i went street racing and got my doors blown off from a 355 horse small block.
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 09-29-2002, 04:27 PM   #2
Dean23
68cst_ss490
Dean23's Avatar
Give me cam specs, compression, carb, headers or not, valve size and I will run it for you
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 09-29-2002, 04:38 PM   #3
Johns70
Johns70's Avatar
its a 396 big block thats been overbored .030,speed pro forged pistons with .180 dome,9.5:1 compression,crane 282 cam with ,533 lift. headers and edelbrock rpm manifold ,750 elenbrock carb,2.06 intake and1.72exhaust.heads were pocket ported and exhaust runners polished.
let me know if you need any more info
Old 09-29-2002, 04:41 PM   #4
Dean23
68cst_ss490
Dean23's Avatar
what is your cam duration
Dean
edmonton,canada
a winter wonderland
Old 09-29-2002, 04:43 PM   #5
Johns70
Johns70's Avatar
upps. 226 at .050 lift
Old 09-29-2002, 04:45 PM   #6
Dean23
68cst_ss490
Dean23's Avatar
oh yeah what intake manifold, single or dual plane, and what kind of lifters, flat tappet or roller
Dean
edmonton,canada
a winter wonderland
Old 09-29-2002, 04:48 PM   #7
Johns70
Johns70's Avatar
eldenbrock performer rpm dual plane, hydralic flat tappet
Old 09-29-2002, 04:54 PM   #8
Dean23
68cst_ss490
Dean23's Avatar
I says 414 hp at 5500 and 435 ft/lbs @ 4000
[IMG]C:\My Documents\Dean[/IMG]
Dean
edmonton,canada
a winter wonderland
Old 09-29-2002, 04:58 PM   #9
Johns70
Johns70's Avatar
thank you i thought it should be around 400 but i didn't think it would be so high in the rpm range of the cam becuase it power band is 2500 to 5500. thanks again john
Old 09-29-2002, 05:10 PM   #10
Dean23
68cst_ss490
Dean23's Avatar
no problem, what rear gears you running. Are you having a problem hooking up. what is your timing set at and what is total advance.
Dean
edmonton,canada
a winter wonderland
Old 09-29-2002, 05:30 PM   #11
Johns70
Johns70's Avatar
runnin 3.73 gears factorylimited slip, not to much with tire spin.not sure on the timing still playing with it. that might be whats fouling me up.
Old 09-29-2002, 07:37 PM   #12
Johngear67
The Mighty Blue Bottle
and when you do make the power you will have trackion problems
weight transfer is the key
1967 Chevy C 10 Custom
350 780 cfm 467 lift 278 dur
ported&pollished
2400 stall 350TH
B&M shifter
175 shot of nitrious
Johngear67 is offline   Reply With Quote
