Old 09-06-2007, 04:20 PM   #1
Mike00
72 Cab replacement ?
My dad gave me his 1972 Chevy pick-up after owning it for 20 years. The cab is pretty much a rust bucket. What years of truck cabs would fit?
Mike00 is offline   Reply With Quote
Old 09-06-2007, 04:30 PM   #2
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Re: 72 Cab replacement ?
all 67 through 72.
bad6772 is offline   Reply With Quote
Old 09-06-2007, 04:35 PM   #3
john
member #16
john's Avatar
A 71-72 with a cable throttle would be a direct bolt on. The 67-70 trucks have a throttle rod, but can be changed with a little work on the firewall.
john is offline   Reply With Quote
Old 09-06-2007, 04:49 PM   #4
Putter
More Cowbell....
Putter's Avatar
That conversion John mentioned can be done like this (or you can weld in the proper sections)...
No-weld throttle conversion
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 09-06-2007, 04:50 PM   #5
HeavyD
HeavyD's Avatar
If you want it to look 100% a '72 is what you need, as it has the proper cable throttle and no provision for mounting the mirror on the roof like a '71 would have.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 09-06-2007, 06:25 PM   #6
Classic Bowties
Always on the hunt...
JMO, go with another 72 cab, they are plentiful and easy enough to find. Also to add to the above, I have found that the firewall provisions for mounting the under dash fuse panels/wiring are different on the earlier cabs. Cb
Classic Bowties is offline   Reply With Quote
Old 09-06-2007, 07:16 PM   #7
Mike00
Cool, thanks guys!!!
Old 09-06-2007, 07:29 PM   #8
wibilly
wibilly's Avatar
and don't forget the vent in the door jamb on the 72s only not that it matters
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 09-07-2007, 10:57 AM   #9
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
And the e-brake differences; handle -vs- foot brake. The upper left firewall area is totally different between the two.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-22-2007, 03:00 PM   #10
eric67m
eric67m's Avatar
Not to hijack the thread but.... Will a brake and clutch pedal assembly from a 67 fit into a 72 cab? Are the firewalls or distance to dash different?
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
