It'd be alot cooler if you did
where's that post?
Yes I searched...
where's the post where the guy did the 2wd to 4wd swap from the truck to the blazer...? |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: where's that post?
This is the 2wd to 4wd conversion, but I think you are wanting 4x4 blazer to 4x2...
http://67-72chevytrucks.com/vboard/s...d.php?t=222438 The Blazer and Truck one is here: http://67-72chevytrucks.com/vboard/s...d.php?t=168231
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
thanks chris! Exactly what I was looking for!
Flat Black, & Chrome!
what ya planning?
No problem Chuck.
Thats awesome that both the blazer and the truck got fixed up and are being driven. I guess the frames for 2wd and 4x4 are the same, it's just a matter of bolting up the front suspension ?
like a rock
![]() Join Date: Nov 2004
no not true, i was unable to bolt the subs front suspension and axle to the
2wd frame. I thought it was going to work after reading the blazer and pickup swap. They were 1/2 ton frames and mine were 3/4 ton. I had mine welded professionally. The frame heights were different. Hope this helps. |
nothing for me... someone on another board was asking about it, needed the link.
The front half of the frames on the 1/2T trucks are the same (Blazer vs Truck) and all trucks are the same as far as the rails go.
3/4T are all the same as each other but not like 1/2T as Vern350 found out.
