Old 09-07-2007, 03:17 AM   #1
combustion
grill finish?
i sanded my grill with 60 grit, then 320 then 600 then 1000 grit sand paper, then after that i polished it with aluminium polish. its nice and shiny right now. but in order to keep it like that, some people in this forum say to clear coat it. well if i do, can i just use the clear coat they sell in a bottle like at auto zone or pep boys? or do i have to use a special kind. will it last? this thing looks perfect. it nearly a mirror image, i just want to keep it that way for longer. thanks
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
combustion is offline   Reply With Quote
Old 09-07-2007, 02:00 PM   #2
combustion
Re: grill finish?
anyone???
bump
Old 09-07-2007, 02:08 PM   #3
AlienYouth
AlienYouth's Avatar
Re: grill finish?
it's aluminum, so it shouldnt rust, so just use chrome polish on it every once in i while and it should be fine, i think... : )
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 09-08-2007, 12:02 AM   #4
wibilly
wibilly's Avatar
Re: grill finish?
i'm doing the same to mine it's looking great but i don't know about the clear coat either. i've seen it peal on wheels and they look awful. i think i'm gonna polish mine and keep it waxed.
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 09-08-2007, 09:12 AM   #5
gotchevys?
gotchevys?'s Avatar
Re: grill finish?
I have tried rustoleum clear on a small polished aluminum braket I made once and bubbled up and looked awful.
I have never used this stuff but its made to spray directly onto bare metal. Most everything I've gotten from eastwood so far has worked great.
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
www.fatdaddieshotrods.com
gotchevys? is offline   Reply With Quote
Old 09-08-2007, 10:23 PM   #6
Bowtie001
Project underway - finally.
Bowtie001's Avatar
Re: grill finish?
OK, coming from a guy that has never done this... I would think paint would be tough because it'll get scratched and stuff hangin out there in the breeze. Maybe wax it?
At any rate, we need pictures... if you got a mirror finish, you're great.
1972 GMC Pre-resto... awaiting allocated funding.
Bowtie001 is offline   Reply With Quote
Old 09-09-2007, 02:38 PM   #7
Dano69c10
Dano69c10's Avatar
Re: grill finish?
Have it anodized.
Just my 2 cents
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 09-09-2007, 03:30 PM   #8
SHORTY '72
SHORTY '72's Avatar
Re: grill finish?
Clear powdercoat?
SHORTY '72 is offline   Reply With Quote
Old 09-09-2007, 04:10 PM   #9
redhead69
fugedaboutit
redhead69's Avatar
Re: grill finish?
did the same to mine a while back.. it will lose its luster after a bit, youve just got to keep it polished to keep the shine. You got all the sand marks out with 1000 grit? I get the same process going up to 2000 grit.. then hit it with some real fine steel wool.. then the polish.
Currently truckless
redhead69 is offline   Reply With Quote
Old 09-09-2007, 04:17 PM   #10
combustion
Re: grill finish?
i do but with aluminum polish they go away. i should just get a repo one or something
Old 09-09-2007, 04:37 PM   #11
redhead69
fugedaboutit
redhead69's Avatar
Re: grill finish?
Yeah me too.. the amount of time I have and will put into it. Im just cheap.
Currently truckless
