Old 09-07-2007, 07:48 AM   #1
Curbstone Mech
Active Member
Changing out my 3/4 ton, 1972 rear
I want to change out my 72 GMC 3/4 rear gears to to 373:1 and posi
Where should I start to look?
68 short fleet
383 stroker, 700r4 373:1 posi
72 GMC 3/4 ton- weekly driver
700r4 351;1 posi
Curbstone Mech is offline   Reply With Quote
Old 09-07-2007, 01:27 PM   #2
Re: Changing out my 3/4 ton, 1972 rear
You might do best to consider a later rear.The 14-bolts came with 3.73 in alot of trucks and you would only need to move one shock mount and the spring pads.That would keep you from setting up a new ring & pinion and the parts purchase.
Old 09-07-2007, 03:11 PM   #3
Curbstone Mech
Active Member
Thanks Tim
That's a start
68 short fleet
700r4 351;1 posi
Old 09-07-2007, 04:31 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
need to start with knowing what's under there now.
Is it a dana?
Is it an Eaton/cororate?
What gear ratio is it?
Old 09-07-2007, 07:31 PM   #5
That`s true.I figured it was a Dana60.There weren`t 3.73s for either,right?
Old 09-07-2007, 09:25 PM   #6
Longhorn Man
correct.
5.something, 4.57, 4.10, 3.56
Old 09-08-2007, 01:29 AM   #7
wibilly
wibilly's Avatar
and the 3.56 only in the dana
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 09-08-2007, 07:40 AM   #8
Yeah,that`s what you`d want.But,finding one?Never tryed replacement parts,but I never see them in Danas,personally.
The Eatons never went as low.Very few 3.90s out there,it seems.I think my to truck has 5.13s or whatever the increment was.I can want as fast as the speed it can be shifted to 4th.Well,power-walk.Now stop visualizing that!
