Old 09-29-2002, 05:56 PM   #1
Jefe
Jefe's Avatar
Holley Carb Identification Help..
I have a Holley carb that a buddy gave me...sais its a 780 cfm, need to know if it is a double pumper, what CFM it is exactly and probably the part number or where it is located on the carborator. I know it is a dual feed square bore...but that's it. Any help would be appreciated, Thanks guys!!
Jefe is offline   Reply With Quote
Old 09-29-2002, 06:16 PM   #2
crazy longhorn
Fabricate till you "puke"
Look on the front of the air horn(dr side) for the #. A dp will have an acc pump on the rearpass side. the vac secondaries wont have this. post the # , & somebody can help.........Crazy Al
crazy longhorn is offline   Reply With Quote
Old 09-29-2002, 07:41 PM   #3
Johngear67
The Mighty Blue Bottle
go to the holley web site and it will give you all of the info you need with the right list number
1967 Chevy C 10 Custom
350 780 cfm 467 lift 278 dur
ported&pollished
2400 stall 350TH
B&M shifter
175 shot of nitrious
Johngear67 is offline   Reply With Quote
Old 09-29-2002, 09:54 PM   #4
Jefe
Jefe's Avatar
ok.
List-3310-1 is what is on there.
then below that it sais 0884. Tried to look at the numbers on the Holly site and it was down or something thanks.
Old 09-29-2002, 10:43 PM   #5
LT-102
3310-1 is a 780 cfm. I may not be correct, but I believe the 0884 indicated that it was built in August of 1984. The Holley site is back up now.
LT-102 is offline   Reply With Quote
Old 09-30-2002, 09:50 AM   #6
crazy longhorn
Your 3310-1 is a 4150(has a rear metering block). as posted, it is a 780 cfm,& has vacumn secondairies. 72 primary jets, & 76 secondairy jets(factory). Renew kit # from my Holley book is 37-332......the trick kit is #37-915. It should be a good all around carb to run on 350- 455 ci engines,with a little tuning for the application. good luck.......crazy Al
