Old 09-07-2007, 04:39 PM   #1
RyanG
RyanG's Avatar
Look what I did!!!!!!!!!!!
After figuring out what was wrong with my tranny not shifting I took her for a test drive and did this . Getting it fixed now. Just wanted to share.......
RyanG is offline   Reply With Quote
Old 09-07-2007, 04:59 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Look what I did!!!!!!!!!!!
Popped the clutch?
Bummer. That's going to set you back a couple, at least.
I need to have my front yoke replaced and shaft balanced. Estimate was about $180.00
68gmsee is offline   Reply With Quote
Old 09-07-2007, 05:04 PM   #3
68gmsee
Active Member
68gmsee's Avatar
ooops forgot you have an automatic...
Old 09-07-2007, 05:07 PM   #4
RyanG
RyanG's Avatar
I am kinda gettn raped on this but I need the truck.......To do both shafts ballanced and u joints replaced along with the towing I am paying just over 500. Towing was 70
Old 09-07-2007, 05:13 PM   #5
70rs/ss
70rs/ss's Avatar
Holy Crap batman!! A new shaft shouldn't cost that much. I had one built from scratch for $150. I'd shop around for a driveshaft shop and have them buid, or fix yours, then install it yourself!!
70rs/ss is offline   Reply With Quote
Old 09-07-2007, 05:16 PM   #6
Sinister
Between Trucks...
Sinister's Avatar
That's a drag, but at least your tranny is shifting...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 09-07-2007, 05:20 PM   #7
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
too much. shop it.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 09-07-2007, 05:23 PM   #8
68gmsee
Active Member
68gmsee's Avatar
If you have a 2 piece, that may be about right. The parts will probably run you $150 to $200, labor at least $200 to $300 (welding, grinding, etc.).
Old 09-07-2007, 05:36 PM   #9
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I disagree. I think $150 for each shaft built from scratch is about right.
Thats what my shop charges.
Old 09-07-2007, 05:45 PM   #10
69GMCor70Chevy
69GMCor70Chevy's Avatar
Same thing happened to me on my K5 a couple of years ago. If I remeber correctly The new yoke and shaft balancing cost $75 and the new U-joints and installation cost me another $125. I was only a block from home so I just took the shaft out and drove it with the front wheels. The worst part for me was that there was no inclination that it was about to occur. No vibration, no sounds or clunking when putting into gear or anything but I was just glad I wasn't going 60 on the highway.
68 Camaro - 327 Original Red on Red Car
69 GMC LWB - Built 350 a Blast To Drive
69 GMC LWB - "Green Machine" One Family Truck
70 Mercury Marauder - Future Project
69GMCor70Chevy is offline   Reply With Quote
Old 09-07-2007, 05:55 PM   #11
68gmsee
Active Member
68gmsee's Avatar
I think what jacked his cost up is the grinding off the old yoke, replacing with new one and welding it back up. Some shops are not equipped with welders that can do a drive shaft and they have to send it out.
It took a professional welder neighbor of mine a couple of hours to remove a yoke with a grinder, reweld the new one and grind it back down on a vehicle of mine some years back...
Old 09-07-2007, 05:56 PM   #12
RyanG
RyanG's Avatar
Yeah ...I have a two piece shaft and am replacing all the ujoints. I don't really have a problem paying that to the guy I took it to because he has helped me out in the past.
Old 09-07-2007, 05:57 PM   #13
RyanG
RyanG's Avatar
It had to be sent out......
Old 09-07-2007, 05:59 PM   #14
72armyswbtruck
72armyswbtruck's Avatar
Damn the luck.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 09-07-2007, 06:00 PM   #15
68gmsee
Active Member
68gmsee's Avatar
Yep, and I forgot to mention that the neighbor used to get about $100 an hour!!!
Old 09-07-2007, 06:02 PM   #16
RyanG
RyanG's Avatar
Originally Posted by 72armyswbtruck View Post
Damn the luck.
I know but hey......once it is done I will have my truck back with a new motor...rebuilt tranny and "new" drive shaft......now to get rid of the rust....get a new wiring harness ...and body off restore and I am in good shape..
Old 09-07-2007, 06:53 PM   #17
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Be happy the rear of it broke and fell. IF the front had broken and dropped and grabbed something, you'd be spending more money.
Did it make any kind of noise before it '86-ed?? Squeek, Clank or any other noise?
Member Nr. 2770
Old 09-07-2007, 07:41 PM   #18
2bits
2bits's Avatar
What was wrong with the tranny? If it ain't one thing, it's ten others!
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
Last edited by 2bits; 09-07-2007 at 07:42 PM. Reason: Edit: Saw it was the Vac line on the other post :)
2bits is offline   Reply With Quote
Old 09-07-2007, 08:36 PM   #19
68gmsee
Active Member
68gmsee's Avatar
It wasn't shifting and he found the vacuum line had slipped off the modulator.
Old 09-07-2007, 11:11 PM   #20
68C15
blood type; Retumbo
68C15's Avatar
same here. on my old 80 K20 I had a pair of super duty guaranteed for life shafts made and with all new Neapco joints it came to just under $300.
68C15 is offline   Reply With Quote
Old 09-07-2007, 11:18 PM   #21
72BlckButy
Tot Roddin'
72BlckButy's Avatar
One step forward.... two steps back!
Sorry to hear of the break down. Hopefully after this is fixed that will be it for a while.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-07-2007, 11:19 PM   #22
Frizzle Fry
Frizzle Fry's Avatar
Also costs more to balance a two piece than a single.
Frizzle Fry is offline   Reply With Quote
Old 09-08-2007, 03:41 AM   #23
RyanG
RyanG's Avatar
You Know it was wierd....I thought I felt a flat tire in the rear but looked and saw nothing.......then after turning a corner it felt like I had a missing tire....then finally it broke free at about 10 miles per hour...thank god I wasn't going any faster.
Old 09-08-2007, 03:43 AM   #24
RyanG
RyanG's Avatar
I know me too ..but with these truck it is always something....wether it be something you want to improve or something that needs to be fixed.
Old 09-08-2007, 03:44 AM   #25
RyanG
RyanG's Avatar
Yep the vaccum line was off.
